path: root/bsps/m68k/mvme147s/headers.am (follow)
* build: Remove old build systemSebastian Huber2021-09-211-10/+0
| | | | | Close #3250. Close #4081.
* bsps: Regenerate headers.amSebastian Huber2019-07-051-0/+4
| | | | Update #3269.
* Remove make preinstallChris Johns2018-01-251-0/+6
