path: root/bsps/m68k/include/bsp/linker-symbols.h (follow)
* Update company nameSebastian Huber2023-05-201-1/+1
| | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
* bsps/m68k/include: Change license to BSD-2Joel Sherrill2022-07-111-3/+22
| | | | Updates #3053.
* bsps/m68k/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-6/+0
| | | | Updates #4625.
* bsps: Adjust shared Doxygen groupsSebastian Huber2019-03-081-2/+2
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+84
