path: root/bsps/lm32/lm32_evr/headers.am (follow)
* build: Remove old build systemSebastian Huber2021-09-211-7/+0
| | | | | Close #3250. Close #4081.
* bsps/lm32: Use shared <bsp/irq.h>Sebastian Huber2020-07-311-4/+0
| | | | | | | | Having a duplicate header with the shared includes is a build system inconsistency. You may use one header file to build the libraries and another one is installed (overwriting the other). Update #3269.
* bsps: Regenerate headers.amSebastian Huber2019-07-051-0/+4
| | | | Update #3269.
* Remove make preinstallChris Johns2018-01-251-0/+7
