path: root/bsps/include/bsp/stackalloc.h (follow)
* Update company nameSebastian Huber2023-05-201-1/+1
| | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
* bsps/include: Change license to BSD-2Joel Sherrill2022-07-111-3/+22
| | | | Updates #3053.
* bsps/include/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-6/+0
| | | | Updates #4625.
* bsps: Adjust architecture Doxygen groupsSebastian Huber2019-03-041-1/+1
| | | | | | | | | | - Use CamelCase as it is not used in our C code. Enables simple search and replace. - Prefix with "RTEMS" to aid deployment and integration. It aids searching and sorting. Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+94
