path: root/bsps/i386/pc386/include/bsp/bspimpl.h (follow)
* bsps/i386/pc386: Change license to BSD-2Joel Sherrill2022-07-111-3/+22
| | | | Updates #3053.
* Remove make preinstallChris Johns2018-01-251-0/+47
