Replace the BSP_CONSOLE_MINOR BSP option for the Xilinx Zynq BSPs with the new
BSP option ZYNQ_UART_KERNEL_IO_BASE_ADDR. Move the kernel I/O support to a
shared file.
Make the initialization and polled functions independent of the Termios
context. This helps to implement the kernel I/O support without a dependency
on the Termios framework.
brains GmbH.
Initialize the debug console only once during early system initialization.
This moves the zynq-uart driver from bsps/arm/shared to bsps/shared to
accomodate use by AArch64 BSPs.
Use RTEMS_SYSINIT_ORDER_LAST_BUT_5 instead of RTEMS_SYSINIT_ORDER_LAST
to allow applications and support functions to place system
initialization handlers behind the standard handlers.
Update #3838.
This variable is BSP specific and should be removed from the driver
header file.
Update #3682.
Relicense contributions from Chris Johns, Christian Mauderer,
embedded brains GmbH, Joel Sherrill, OAR, Pavel Pisa, Ralf Kirchner, and
Sebastian Huber.
Update #3053.
Update #3285.
