path: root/bsps/arm/tms570/include/bsp.h (follow)
* bsp/tms570: Use TMS570_OSCILLATOR_MAINSebastian Huber2024-01-151-2/+0
| | | | | | | This option replaces BSP_OSCILATOR_CLOCK. It may be used in PLL setup calculatios. Update #4982.
* bsp/tms570: Add bsp_restart()Sebastian Huber2024-01-151-0/+2
| | | | Update #4982.
* bsp/tms570: Relicense to BSD-2-ClauseSebastian Huber2024-01-151-6/+23
| | | | | | | | | Change license to BSD-2-Clause according to file history and contributor agreements. Add Doxygen file comments. Update #3053. Update #3707. Update #4982.
* bsp/tms570: Adjust BSP_OSCILATOR_CLOCKSebastian Huber2023-12-061-0/+5
* bsps: Adjust bsp.h Doxygen groupsSebastian Huber2019-03-081-1/+13
| | | | Update #3706.
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* Remove make preinstallChris Johns2018-01-251-0/+42
