path: root/bsps/arm/stm32f4/include/bsp/stm32_i2c.h (follow)
* bsps/arm/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-6/+0
| | | | Updates #4625.
* Remove make preinstallChris Johns2018-01-251-0/+113
