path: root/bsps/arm/raspberrypi/headers.am (follow)
* build: Remove old build systemSebastian Huber2021-09-211-20/+0
| | | | | Close #3250. Close #4081.
* Remove make preinstallChris Johns2018-01-251-0/+20
