path: root/bsps/arm/lpc32xx/include/bsp/lpc-clock-config.h (follow)
* Update company nameSebastian Huber2023-05-201-1/+1
| | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
* bsps/arm/lpc32xx: Change license to BSD-2Joel Sherrill2022-07-081-3/+22
| | | | Updates #3053.
* bsps/arm/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-6/+1
| | | | Updates #4625.
* bsps: Adjust bsp.h Doxygen groupsSebastian Huber2019-03-081-1/+1
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+59
