* | lm3s3749-testsuite.tcfg: Add spcxx01 | Joel Sherrill | 2020-10-12 | 1 | -0/+1 |
* | lm4f120-testsuite.tcfg: Add psxsignal07 | Joel Sherrill | 2020-04-07 | 1 | -0/+1 |
| | | | | Updates #3938. | ||||
* | lm3s3749-testsuite.tcfg: Add ttest01 | Joel Sherrill | 2020-03-12 | 1 | -0/+1 |
* | bsps/arm: Adjust machine flags for ARMv7-M | Sebastian Huber | 2019-05-14 | 1 | -1/+1 |
| | | | | | | | Update machine flags for Cortex-M3 and Cortex-M4 based BSPs to account for Cortex-M3 Errata 602117 which required GCC multilib changes. Update #3747. | ||||
* | bsp/lm3s69xx: Fix typo in test configuration | Sebastian Huber | 2019-03-13 | 2 | -2/+1 |
* | lm4f120-testsuite.tcfg: Update to account for static allocation and BSP ↵ | Joel Sherrill | 2019-03-12 | 1 | -49/+2 |
| | | | | small memory | ||||
* | lm3s6965-testsuite.tcfg: Update to account for static allocation and BSP ↵ | Joel Sherrill | 2019-03-12 | 1 | -0/+2 |
| | | | | small memory | ||||
* | lm3s3749-testsuite.tcfg: Update to account for static allocation and BSP ↵ | Joel Sherrill | 2019-03-12 | 1 | -0/+7 |
| | | | | small memory | ||||
* | bsp/lm4f120: Disable unsupported tests | Sebastian Huber | 2019-03-04 | 1 | -6/+64 |
* | lm3s3749-testsuite.tcfg: Add dl07 | Joel Sherrill | 2018-11-28 | 1 | -0/+1 |
* | bsps: Move make/custom/* files to bsps | Sebastian Huber | 2018-04-23 | 8 | -0/+126 |
Adjust various build files. Remove automatic generation of the c/src/lib/libbsp/*/acinclude.m4 files from bootstrap script. This patch is a part of the BSP source reorganization. Update #3285. |
