path: root/bsps/arm/imx/include/tm27.h (follow)
* Update company nameSebastian Huber2023-05-201-1/+1
| | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
* bsps/arm/imx: Change license to BSD-2Joel Sherrill2022-07-081-3/+22
| | | | Updates #3053.
* bsps/arm/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-6/+0
| | | | Updates #4625.
* bsps: Break out AArch32 GICv3 supportKinsey Moore2020-10-051-1/+1
| | | | | This breaks out AArch32-specific code so that the shared GICv3 code can be reused by other architectures.
* Remove make preinstallChris Johns2018-01-251-0/+24
