* custom/dmv177.cfg: Use -mcpu=603e.
* custom/ppcn_60x.cfg: Use -mcpu=603e.
* custom/psim.cfg: Use -mcpu=603e.
* custom/score603e.cfg: Use -mcpu=603e.
* custom/ts_386ex.cfg: Remove obsolete comments.
* custom/rxgen960.cfg: Remove obsolete comments.
* custom/cvme961.cfg: Remove obsolete comments.
* sp21/task1.c: Correct INVALID_DRIVER_MAJOR so it is precisely 1 more
than the configured number of drivers.
* c/src/libchip/network/i82586.c: Per PR210, adjust the mbuf
lengths to remove the ethernet header as the FreeBSD (RTEMS)
stack requires it to be stripped.
* src/m68k/rdbg_cpu_asm.S: Per PR163, Fix incorrect assumption that
exception stack frames on M68K members with VBR always are 6 byte long.
The incorrect assumption resulted in some gdb commands like "next"
to fail on the 68360.
* src/i386/any/remdeb_svc.c, src/m68k/any/remdeb_svc.c,
src/powerpc/new_exception_processing/remdeb_svc.c: Per PR220 remove
these files from CVS.
* custom/jmr3904.cfg, custom/p4650.cfg: Add comments for gcc 3.1
compatable arguments.
* include/i960CA.h, include/i960RP.h: Correct inline assembly
forward reference labels.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* startup/linkcmds.real: Ditto.
* clock/ckinit.c: Add volatile to Clock_driver_ticks.
* src/exinit.c: Slightly rework initialization so there
is a valid thread as _Thread_Executing when the pre_tasking
hook is called. This allows one directives and malloc
to potentially use mutex protection.
* lock-directory.in, unlock-directory.in: Removed.
* Makefile.am, README, .cvsignore: Updated to reflect above.
* custom/Makefile.am: Remove.
* compilers/Makefile.am: Remove.
* compilers/.cvsignore: Remove.
* Makefile.am: Merge-in former */Makefile.ams.
Add more vars to <BSP>.cache.
* configure.ac: Reflect changes above. Cosmetic fixes.
* machine/in_cksum.h: Per PR200 fix multi-line inline assembly
to satisfy gcc 3.1 and newer.
* console/console.c, fatal/bspfatal.c, startup/bspclean.c,
startup/page_table.c: Per PR200 fix multi-line inline assembly
* rtems/powerpc/cache.h: New file (extracted from
old-exceptions/cpu.h)
* Makefile.am: Relect changes above.
* cpu.c: Include <rtems/powerpc/cache.h>.
* rtems/score/ppc.h: Remove rtems_multilib.
Add mpc555 (Based on comments from Sergei Organov <osv@javad.ru>).
* rtems/old-exceptions/cpu.h: Remove _CPU_Data_Cache_Block_Flush.
Remove _CPU_Data_Cache_Block_Invalidate.
* monitor/mon-command.c: Per PR192 the RTEMS monitor makes everything
lowercase. The capture engine need to set triggers or watches on task
with uppercase names.
Also stop the monitor repeating command when enter is pressed.
* startup/spurious.c: Use defined(mpc604) instead of defined(ppc604).
* src/objectcomparenamestring.c: Fix typos.
* include/rtems/score/object.h, inline/rtems/score/object.inl,
src/objectcomparenamestring.c: Address PR81 that
reworked POSIX message queues to add a descriptor separate from
the underlying message queue. This allows non-blocking to follow
the "open" not the underlying queue. As part of debugging this
it became clear that _Objects_Compare_name_string was broken
and a simple version using strncmp() was substituted.
* psxmsgq01/init.c: Reflect changes made to address PR81 that
* include/rtems/posix/mqueue.h, inline/rtems/posix/mqueue.inl,
src/mqueue.c, src/mqueueclose.c, src/mqueuecreatesupp.c,
src/mqueuegetattr.c, src/mqueuenotify.c, src/mqueueopen.c,
src/mqueuerecvsupp.c, src/mqueuesendsupp.c, src/mqueuesetattr.c:
Per PR81 reworked to add a message queue descriptor separate from
* include/bsp.h: Change SIS to ERC32_BSP.
* libc/gxx_wrappers.c: Fix to keep prototype same as in gcc and
remove warning.
* netinet/in_cksum_i386.c: Add volatile so the more agressive
optimization in gcc 3.1 does not reorder things.
* src/task.c (_ITRON_Task_User_extensions): Add new fields to
be correct in respect to newly added fields for separate switch list.
* src/powerpc/rdbg_f.c: Always include <rtems.h> instead of
internal include files.
* start/start.S: remove targopts.h.
* asm.h: Use cpuopts.h instead of targopts.h.
* rtems/score/hppa.h: Remove rtems/score/targopts.h.
* src/powerpc/rdbg_cpu_asm.S: Reflect changes to
<rtems/score/cpu.h>.
* src/powerpc/rdbg_f.c: Ditto.
* pppd/utils.c: Adapt to gcc-3.x.
* network/dec21140.c: Reflect changes to powerpc's
rtems/score/cpu.h. Use __PPC__ for gcc-3.x compliance.
* shared/include/cpu.h: Removed.
* shared/include/Makefile.am: Reflect changes above.
* shared/include/spr.h: Include rtems/powerpc/registers.h instead of
libcpu/cpu.h.
* mpc6xx/clock/c_clock.c: Reflect changes to <rtems/score/cpu.h>.
* mpc6xx/exceptions/asm_utils.S: Ditto.
* mpc6xx/exceptions/raw_exception.c: Ditto.
* mpc6xx/mmu/mmuAsm.S: Ditto.
* mpc6xx/timer/timer.c: Ditto.
* mpc8260/exceptions/asm_utils.S: Ditto.
* mpc8260/exceptions/raw_exception.c: Ditto.
* mpc8xx/exceptions/asm_utils.S: Ditto.
* mpc8xx/exceptions/raw_exception.c: Ditto.
* ppc403/vectors/vectors.S: Include <asm.h> instead of "asm.h".
* rtems/score/cpu.h: Removed.
* bootloader/exception.S: Reflect changes to <rtems/score/cpu.h>.
* bootloader/head.S: Ditto.
* bootloader/misc.c: Ditto.
* console/polled_io.c: Ditto.
* irq/irq.c: Ditto.
* irq/irq_asm.S: Ditto.
* irq/irq_init.c: Include <rtems/bspIo.h>.
* start/start.S: Reflect changes to <rtems/score/cpu.h>.
* vectors/vectors.S: Ditto.
* vectors/vectors.S: Include <asm.h>.
* startup/bspstart.c: Include <rtems/bspIo.h>.
* vectors/align_h.S: Use <> instead of "" for include files.
* irq/irq.c: Reflect changes to <rtems/score/cpu.h>.
* network/network.c: Include <rtems/bspIo.h>.
* start/start.S: Include <asm.h> instead of "asm.h".
* vectors/vectors.S: Reflect changes to <rtems/score/cpu.h>.
Fix loopCounter.
* irq/irq_asm.S: Reflect changes to <rtems/score/cpu.h>.
* vectors/vectors_init.c: Include <rtems/bspIo.h>.
* irq/irq.c: Reflect changed to <rtems/score/cpu.h>.
* asm.h: Include cpuopts.h instead of targopts.h.
* rtems/new-exceptions/cpu.h: Relocated from
libbsp/powerpc/support/new_exception_processing/rtems/score/cpu.h
* rtems/old-exceptions/cpu.h: Relocated from
c/src/lib/libbsp/powerpc/support/old_exception_processing/rtems/score/cpu.h
* rtems/powerpc/registers.h: Relocated and renamed from
libcpu/powerpc/shared/include/cpu.h.
* rtems/score/cpu.h: New.
* startup/nulsystbl.c: Fix braces.
* startup/Makefile.am: Remove types.h.
* startup/types.h: Remove.
* rtems/score/cpu.h (CPU_ISR_Disable and CPU_ISR_Enable): Correct them
where they correctly inform the compiler about the register they
are modifying.
* gcc3newlib/gccnewlib.add: Add gcc_update --touch to fix
timestamps.
* include/rtems/system.h: Remove targopts.h.
* custom/dmv177.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS.
* custom/eth_comm.cfg: Remove make-target-options.
Add -Dmpc$(CPU_TYPE) -DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF to
CPU_CFLAGS.
* custom/gen405.cfg: Add -D_OLD_EXCEPTIONS -Dppc405 to CPU_CFLAGS.
* custom/helas403.cfg: Add -D_OLD_EXCEPTIONS -Dppc403 to CPU_CFLAGS.
* custom/mbx8xx.cfg: Remove make-target-options.
Add -Dmpc$(CPU_TYPE) -D$(RTEMS_MBX_MODEL) to CPU_CFLAGS.
* custom/mcp750.cfg: Add -Dmpc750 to CPU_CFLAGS.
* custom/mpc8260ads.cfg: Remove make-target-options.
Add -Dmpc8260 -DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF to
CPU_CFLAGS.
* custom/mvme2307.cfg: Add -Dmpc604 to CPU_CFLAGS.
* custom/ppcn_60x.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to
CPU_CFLAGS.
* custom/psim.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS.
* custom/score603e.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to
CPU_CFLAGS.
* shared/include/cpu.h: Added ifndef ASM.
