PR 441/filesystem
*src/dosfs/msdos.h: add rename support to DOSFS
*src/dosfs/msdos_create.c: add rename support to DOSFS
*src/dosfs/msdos_file.c: add rename support to DOSFS
*src/dosfs/msdos_init.c: add rename support to DOSFS
*src/dosfs/msdos_mknod.c: add rename support to DOSFS
PR 441/filesystem
* configure.ac: Use relative dir to make/${RTEMS_BSP}.cache.
* configure.ac: Merge-in librdbg/configure.ac.
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am, include/Makefile.am, include/rdbg/Makefile.am,
include/rdbg/i386/Makefile.am, include/rdbg/m68k/Makefile.am,
include/rdbg/powerpc/Makefile.am, src/Makefile.am,
src/i386/Makefile.am, src/i386/any/Makefile.am,
src/m68k/Makefile.am, src/m68k/any/Makefile.am,
src/powerpc/Makefile.am,
src/powerpc/new_exception_processing/Makefile.am:
* ide/Makefile.am, network/Makefile.am, rtc/Makefile.am,
serial/Makefile.am: Add conditional LIBCHIP.
Conditionally build include-dirs.
* network/if_fxp.c: Replace deprecated b* funcs by mem* funcs.
* network/if_hdlcsubr.c: Use memcopy instead of bcmp,
Use memcmp instead of bcmp.
* configure.ac: Merge-in libnetworking/configure.ac.
Merge-in parts of librdbg/configure.ac.
* .cvsignore, Makefile.am, pppd/Makefile.am,
rtems_servers/Makefile.am, rtems_telnetd/Makefile.am,
rtems_webserver/Makefile.am, wrapup/Makefile.am:
PR 434/filesystem
* src/imfs/imfs_init.c: Modified to return error code
* src/imfs/miniimfs_init.c: Modified to return error code
* src/imfs/imfs_initsup.c: Modified to set error upon memory failure.
PR 434/filesystem
PR 288/rtems
* support/new_exception_processing/cpu.c: _ISR_Nest_level is now
properly maintained and does not reside in SPRG0.
PR 288/rtems
* rtems/new-exceptions/cpu.h: _ISR_Nest_level is now properly
PR 288/rtems
* irq/irq_asm.S, startup/bspstart.c: _ISR_Nest_level is now properly
maintained and any BSP which does not do so will trip a panic in the
shared code.
PR 288/rtems
* startup/bspstart.c: _ISR_Nest_level is now properly maintained.
PR 288/rtems
maintained.
PR 415/bsps
* pci/detect_raven_bridge.c, startup/bspstart.c:
This patch reverts enabling MCP interrupts for the motorola_powerpc
BSPs. REASON: pci config space scanning (as e.g. done by the DEC
Ethernet driver) would raise machine check exceptions.
PR 428/bsps
PR 432/bsps
* bootloader/pci.c: Re-instated code that prevents remapping small
IO regions, which if remapped would cause i8259 registers to move
out from under the #define'd base addresses.
* startup/bspstart.c: Reduced BAT2 PCI memory allocation to 256
megs, I incorrectly had extended it which would cause problems with
PCI devices that defined prefetchable memory.
PR 428/bsps
PR 432/bsps
* pci/pcibios.c, pci/pcibios.h: Added BSP_pci_Find_Device() which
is copied from motorola_shared.
PR 429/bsps
PR 432/bsps
* network/elnk.c: Due to a bug in the driver, if multiple packets
are queued onto an elnk board, the ISR will deadlock the device with
a tx complete interrupt. Lighter tx loads are not affected as they
end up submitting single packets to the device.
PR 430/rtems
* include/rtems/score/watchdog.h: _Watchdog_Ticks_since_boot should
be a VOLATILE variable.
* src/watchdoginsert.c: 'restart' algorithm needs to enforce
reloading the list head in case a TICK interrupt during ISR_Flash()
modified the list. This is achieved by a proper VOLATILE cast.
Also _Watchdog_Sync_count++ should be protected by _ISR_Disable
(prevent corruption in case ISR calls watchdoginsert)
* src/watchdogadjust.c: ISR protection added.
* src/watchdogtickle.c: ISR protection added.
NOTE: PowerPC BSPs using the new exception processing MUST BE UPDATED
to maintain _ISR_Nest_level. See also PR288 which provides fixes
for the affected BSPs distributed with RTEMS.
* src/rdbg.c: Use memset instead of bzero (deprecated).
* src/servtsp.c: Ditto.
PR 433/tools
* mips-stub.c: Patch from C. M. Heard <heard@pobox.com> described as:
The purpose of the patch is to make the stub ignore all
characters except '+' (ack) or '-' (nak) when it has transmitted a
packet and expects an acknowledgment. Without the patch,
putpacket() will retransmit each time it receives anything other
than '+' when expecting an ack, and that, bitter experience has
found, frequently results in the stub failing to sync up when
initially attaching to gdb.
I think that rtems users will notice significant improvement in
the of the mips stub if this patch is incorporated in the
distribution; certainly I did in my stand-aline environment. I
should hasten to add that it is only an improvement and not a 100%
cure for synchronization problems because '+' characters can (and
do) during as message data, and it's still possible for these to
be mistaken as acks. I have no idea how to fix that short of
redesigning the gdb-remote protocol.
* ChangeLog: Correct format.
* wrapup/Makefile.am: Remove bogus $(MULTISUBDIR).
* config-ml.in: Partial sync with gcc-3.4's config-ml.in.
Add "autoconf-2.5x unquoting" hack.
opertations will wait for ever.
will wait for ever.
* config.sub: Remove (Automatically added by automake, again).
* bootstrap: Reflect change above.
* configure.ac: Require automake >= 1.7.6.
* autotools/automake-rtems.spec.in: Automake-1.7.6.
* Makefile.am:
* Makefile.am, ide/Makefile.am, network/Makefile.am,
rtc/Makefile.am, serial/Makefile.am:
* configure.ac: Merge-in libchip/configure.ac.
Merge-in optman/configure.ac.
* ada.am: Add .adp to SUFFIXES.
Remove c-compilation rule.
* samples/base_sp/Makefile.am: Add init.$(OBJEXT).
* samples/hello/Makefile.am: Add init.$(OBJEXT).
* samples/ticker/Makefile.am: Add init.$(OBJEXT).
* samples/ticker/Makefile.am: Remove VPATH.
* sptests/sp01/Makefile.am: Add init.$(OBJEXT).
* sptests/sp01/Makefile.am: Don't include */lib.am.
* sptests/sp01/Makefile.am: Remove VPATH.
* sptests/sp02/Makefile.am: Add init.$(OBJEXT).
* sptests/sp02/Makefile.am: Don't include */lib.am.
* sptests/sp03/Makefile.am: Add init.$(OBJEXT).
* sptests/sp03/Makefile.am: Don't include */lib.am.
* sptests/sp04/Makefile.am: Add init.$(OBJEXT).
* sptests/sp04/Makefile.am: Don't include */lib.am.
* sptests/sp04/Makefile.am: Remove EXPADA.
* sptests/sp04/Makefile.am: Remove VPATH.
* sptests/sp05/Makefile.am: Add init.$(OBJEXT).
* sptests/sp05/Makefile.am: Don't include */lib.am.
* sptests/sp06/Makefile.am: Add init.$(OBJEXT).
* sptests/sp06/Makefile.am: Don't include */lib.am.
* sptests/sp07/Makefile.am: Add init.$(OBJEXT).
* sptests/sp07/Makefile.am: Don't include */lib.am.
* sptests/sp07/Makefile.am: Remove EXPADA.
* sptests/sp08/Makefile.am: Add init.$(OBJEXT).
* sptests/sp08/Makefile.am: Don't include */lib.am.
* sptests/sp09/Makefile.am: Add init.$(OBJEXT).
* sptests/sp09/Makefile.am: Don't include */lib.am.
* sptests/sp11/Makefile.am: Add init.$(OBJEXT).
* sptests/sp11/Makefile.am: Don't include */lib.am.
* sptests/sp12/Makefile.am: Add init.$(OBJEXT).
* sptests/sp12/Makefile.am: Don't include */lib.am.
* sptests/sp13/Makefile.am: Add init.$(OBJEXT).
* sptests/sp13/Makefile.am: Don't include */lib.am.
* sptests/sp14/Makefile.am: Add init.$(OBJEXT).
* sptests/sp14/Makefile.am: Don't include */lib.am.
* sptests/sp15/Makefile.am: Add init.$(OBJEXT).
* sptests/sp15/Makefile.am: Don't include */lib.am.
* sptests/sp16/Makefile.am: Add init.$(OBJEXT).
* sptests/sp16/Makefile.am: Don't include */lib.am.
* sptests/sp17/Makefile.am: Add init.$(OBJEXT).
* sptests/sp17/Makefile.am: Don't include */lib.am.
* sptests/sp19/Makefile.am: Add init.$(OBJEXT).
* sptests/sp19/Makefile.am: Don't include */lib.am.
* sptests/sp20/Makefile.am: Add init.$(OBJEXT).
* sptests/sp20/Makefile.am: Don't include */lib.am.
* sptests/sp21/Makefile.am: Add init.$(OBJEXT).
* sptests/sp21/Makefile.am: Don't include */lib.am.
* sptests/sp22/Makefile.am: Add init.$(OBJEXT).
* sptests/sp22/Makefile.am: Don't include */lib.am.
* sptests/sp23/Makefile.am: Add init.$(OBJEXT).
* sptests/sp23/Makefile.am: Don't include */lib.am.
* sptests/sp24/Makefile.am: Add init.$(OBJEXT).
* sptests/sp24/Makefile.am: Don't include */lib.am.
* sptests/sp25/Makefile.am: Add init.$(OBJEXT).
* sptests/sp25/Makefile.am: Don't include */lib.am.
* sptests/spsize/Makefile.am: Add init.$(OBJEXT).
* sptests/spsize/Makefile.am: Don't include */lib.am.
* tmtests/tm01/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm01/Makefile.am: Don't include */lib.am.
* tmtests/tm02/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm02/Makefile.am: Don't include */lib.am.
* tmtests/tm03/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm03/Makefile.am: Don't include */lib.am.
* tmtests/tm04/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm04/Makefile.am: Don't include */lib.am.
* tmtests/tm05/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm05/Makefile.am: Don't include */lib.am.
* tmtests/tm06/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm06/Makefile.am: Don't include */lib.am.
* tmtests/tm07/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm07/Makefile.am: Don't include */lib.am.
* tmtests/tm08/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm08/Makefile.am: Don't include */lib.am.
* tmtests/tm09/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm09/Makefile.am: Don't include */lib.am.
* tmtests/tm10/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm10/Makefile.am: Don't include */lib.am.
* tmtests/tm11/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm11/Makefile.am: Don't include */lib.am.
* tmtests/tm12/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm12/Makefile.am: Don't include */lib.am.
* tmtests/tm13/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm13/Makefile.am: Don't include */lib.am.
* tmtests/tm14/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm14/Makefile.am: Don't include */lib.am.
* tmtests/tm15/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm15/Makefile.am: Don't include */lib.am.
* tmtests/tm16/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm16/Makefile.am: Don't include */lib.am.
* tmtests/tm17/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm17/Makefile.am: Don't include */lib.am.
* tmtests/tm18/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm18/Makefile.am: Don't include */lib.am.
* tmtests/tm19/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm19/Makefile.am: Don't include */lib.am.
* tmtests/tm20/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm20/Makefile.am: Don't include */lib.am.
* tmtests/tm21/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm21/Makefile.am: Don't include */lib.am.
* tmtests/tm22/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm22/Makefile.am: Don't include */lib.am.
* tmtests/tm23/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm23/Makefile.am: Don't include */lib.am.
* tmtests/tm24/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm24/Makefile.am: Don't include */lib.am.
* tmtests/tm25/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm25/Makefile.am: Don't include */lib.am.
* tmtests/tm28/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm28/Makefile.am: Don't include */lib.am.
* tmtests/tm29/Makefile.am: Add init.$(OBJEXT).
* tmtests/tm29/Makefile.am: Don't include */lib.am.
* tmtests/tmck/Makefile.am: Add init.$(OBJEXT).
* tmtests/tmck/Makefile.am: Don't include */lib.am.
* tmtests/tmoverhd/Makefile.am: Add init.$(OBJEXT).
* tmtests/tmoverhd/Makefile.am: Don't include */lib.am.
* configure.ac: Remove (Merged-in into ../configure.ac)
* Makefile.am, include/Makefile.am, src/Makefile.am,
src/rpc/Makefile.am, src/xdr/Makefile.am:
* console/console.c: Correct typo.
* cpu/Makefile.am: Add DIST_SUBDIRS = $(RTEMS_CPU).
* configure.ac: Merge-in librpc/configure.ac.
* Makefile.am: Add librpc to SUBDIRS.
Remove @subdirs@.
PR 418/ada
* rtems.adb: Add missing all keyword to derefence pointer.
PR 416/bsps
* ppc403/ictrl/ictrl.c (ictrl_isr): We acknolwegde the interrupt in
interrupt controller (clr_exisr(mask)) before calling the interrupt
handler that will acnowledge the interrupt source. This results in
the interrupt beeing seen a second time by the interrupt controller.
Reported and fixed by El Kolli Yacine <yacine.elkolli@crf.canon.fr>.
PR 419/rtems
* src/termios.c: Removed warning.
* configure.ac: Merge-in libcsupport/configure.ac.
* Makefile.am: Add libcsupport to SUBDIRS.
* Makefile.am: DOC_FILES = src/TODO src/CASES,
* src/config.h: New.
* configure.ac: Merge-in posix/configure.ac.
Merge-in itron/configure.ac.
Misc. cosmetical changes.
* Makefile.am: Add posix, itron to SUBDIRS.
