path: root/rtemsbsd/sys/dev/iicbus (follow)
* iicbus/rtems-i2c.c: Add rtems,path as an additional bus pathG S Niteesh Babu2021-04-221-3/+5
| | | | | | Adds "rtems,path" as an additional bus path for the i2c driver. Previously the bus path was provided in "rtems,i2c-path" property only.
* Add rtems i2c adaptation layerVijay Kumar Banerjee2019-06-291-0/+231
