This prototype should have been removed with commit
ac4db4cec5b6b1e0a25e910851e50831afb0749d.
This disables any usage of the on-device R/W cache since all device
cache maintenance functions are compiled out under RTEMS leaving no way
to flush the cache before system reset and making data loss possible.
Adds a driver for the i.MXRT1166 USB PHY and enable USB for the
imxrt11xx BSPs.
The BSP needs the CPU_DATA_CACHE_ALIGNMENT set to enable correct cache
handling in libbsd. Otherwise for example USB doesn't work reliable.
The racoon session code copies an fd_set from one variable into another
prior to calling select. That works well for simple structures.
In libbsd we have to allocate fd_sets instead of using fixed structures
to avoid a problem with file numbers bigger than FD_SETSIZE. The simple
assignment didn't work in that case.
This patch makes sure that a memcpy is used instead.
Update #4913
Updates #4860
Git commit 5d85e12f44ccb0e5728344a002c108ddc105e038.
Add two underscore characters "__" to names of BIT_* and BITSET_*
macros to move them to the implementation name space and to prevent
a name space pollution due to BIT_* macros in 3rd party programs with
conflicting parameter signatures.
These prefixed macro names are used in kernel header files to define
macros in e.g. sched.h, sys/cpuset.h and sys/domainset.h.
If C programs are built with either -D_KERNEL (automatically passed
when building a kernel or kernel modules) or -D_WANT_FREENBSD_BITSET
(or this macros is defined in the source code before including the
bitset macros), then all macros are made visible with their previous
names, too. E.g., both __BIT_SET() and BIT_SET() are visible with
either of _KERNEL or _WANT_FREEBSD_BITSET defined.
The main reason for this change is that some 3rd party sources
including sched.h have been found to contain conflicting BIT_*
macros.
As a work-around, parts of shed.h have been made conditional and
depend on _WITH_CPU_SET_T being set when sched.h is included.
Ports that expect the full functionality provided by sched.h need
to be built with -D_WITH_CPU_SET_T. But this leads to conflicts if
BIT_* macros are defined in that program, too.
This patch set makes all of sched.h visible again without this
parameter being passed and without any name space pollution due
to BIT_* macros becoming visible when sched.h is included.
This patch set will be backported to the STABLE branches, but ports
will need to use -D_WITH_CPU_SET_T as long as there are supported
releases that do not contain these patches.
Reviewed by: kib, markj
MFC after: 1 month
Relnotes: yes
Differential Revision: https://reviews.freebsd.org/D33235
This avoids the need for a transmit task and transmit interrupts.
Move the transmit initialization out of the transmit task to be able to
remove the transmit task in the next patch.
The standard FreeBSD MII support causes severe problems on the LPC3200
chip family. If an Ethernet module register is accessed while there is
no clock from the PHY, the chip completely locks up and only an external
watchdog can recover from this state. The legacy driver had a custom
PHY management code which helped to avoid such issues. The if_lpe.c
driver is no longer maintained by FreeBSD.
Required by FreeBSD commit:
Author: Mike Karels <karels@FreeBSD.org>
Date: Tue Oct 26 22:01:09 2021 -0500
kernel: deprecate Internet Class A/B/C
Hide historical Class A/B/C macros unless IN_HISTORICAL_NETS is defined;
define it for user level. Define IN_MULTICAST separately from IN_CLASSD,
and use it in pf instead of IN_CLASSD. Stop using class for setting
default masks when not specified; instead, define new default mask
(24 bits). Warn when an Internet address is set without a mask.
MFC after: 1 month
Reviewed by: cy
Differential Revision: https://reviews.freebsd.org/D32708
Reviewed by: hselasky, jhb, kp (previous version)
Sponsored by: NVIDIA Networking
MFC after: 3 weeks
Differential revision: https://reviews.freebsd.org/D32551
Without this patch, the MSG_TLSAPPDATA flag would cause
soreceive_generic() to return ENXIO for any non-application
data record in a TLS receive stream.
This works ok for TLS1.2, since Alert records appear to be
the only non-application data records received.
However, for TLS1.3, there can be post-handshake handshake
records, such as NewSessionKey sent to the client from the
server. These handshake records cannot be handled by the
upcall which does an SSL_read() with length == 0.
It appears that the client can simply throw away these
NewSessionKey records, but to do so, it needs to receive
them within the kernel.
This patch modifies the semantics of MSG_TLSAPPDATA slightly,
so that it only applies to Alert records and not Handshake
records. It is needed to allow the krpc to work with KTLS1.3.
MFC after: 2 weeks
Differential Revision: https://reviews.freebsd.org/D35170
Widen the ifnet_detach_sxlock to cover the entire vnet sysuninit code.
This ensures that we can't end up having the vnet_sysuninit free the UDP
pcb while the detach code is running and trying to purge the UDP pcb.
MFC after: 1 week
Differential Revision: https://reviews.freebsd.org/D28530
TLS data records.
The kernel RPC cannot process non-application data records when
using TLS. It must to an upcall to a userspace daemon that will
call SSL_read() to process them.
This patch adds a new flag called MSG_TLSAPPDATA that the kernel
RPC can use to tell sorecieve() to return ENXIO instead of a non-application
data record, when that is what is at the top of the receive queue.
I put the code in #ifdef KERN_TLS/#endif, although it will build without
that, so that it is recognized as only useful when KERN_TLS is enabled.
The alternative to doing this is to have the kernel RPC re-queue the
non-application data message after receiving it, but that seems more
complicated and might introduce message ordering issues when there
are multiple non-application data records one after another.
I do not know what, if any, changes will be required to support TLS1.3.
Reviewed by: glebius
Differential Revision: https://reviews.freebsd.org/D25923
This is required for recent Newlib versions.
Update #4667.
Make sure the flags are present in all build configurations.
This avoids issues with the fd_set size.
The i.MX6UL (and some others from the i.MX family) have shared MDIO
lines for multiple FFECs. This patch allows to use the MDIO interface
from another Ethernet controller.
Note that you have to make sure that the FFECs are initialized in the
right order. Normally that can be done via FDT.
Typical embedded systems don't have that much memory. Reduce the buffer
size to something more sensible for the usual type of application.
FreeBSD in 2019 moved crc32 function into separate gsb_crc32.h header
file and probably after libbsd sync with this change if_stmac got broken.
Under unknown conditions the receive path ended up in a frozen state.
In this state, the DMA and driver descriptor head were equal and all
receive descriptors had the used bit set. So, the DMA was unable to
store received frames. However, the receive daemon was never woken up
to refill the receive buffers. It seems that the RXUBR interrupt can be
used to recover from this state.
Update #4652.
Update #4652.
Update #4652.
Update #4652.
Update #4652.
