* | Update to FreeBSD head 2019-09-24 | Sebastian Huber | 2019-11-13 | 1 | -10/+2 |
| | | | | Git mirror commit 6b0307a0a5184339393f555d5d424190d8a8277a. | ||||
* | Update to FreeBSD head 2018-09-17 | Sebastian Huber | 2018-09-21 | 1 | -90/+4 |
| | | | | | | Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319. Update #3472. | ||||
* | Update to FreeBSD head 2018-06-01 | Sebastian Huber | 2018-09-21 | 1 | -6/+8 |
| | | | | | | Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9. Update #3472. | ||||
* | Update to FreeBSD head 2017-12-01 | Sebastian Huber | 2018-09-21 | 4 | -0/+8 |
| | | | | | | Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266. Update #3472. | ||||
* | Update to FreeBSD head 2017-10-01 | Sebastian Huber | 2018-09-21 | 2 | -0/+21 |
| | | | | | | Git mirror commit b2f0376b45428f13151d229c5ae9d4d8f74acbd1. Update #3472. | ||||
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Update to FreeBSD head 2017-01-09 | Sebastian Huber | 2017-01-10 | 1 | -0/+5 |
| | | | | Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab. | ||||
* | Update to FreeBSD head 2016-12-10 | Sebastian Huber | 2017-01-10 | 2 | -2/+16 |
| | | | | Git mirror commit 80c55f08a05ab3b26a73b226ccb56adc3122a55c. | ||||
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 3 | -551/+174 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | Directly use <sys/types.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 1 | -1/+1 |
* | Delete superfluous pci_cfgreg.h files | Sebastian Huber | 2015-09-01 | 1 | -60/+0 |
* | Delete superfluous legacyvar.h files | Sebastian Huber | 2015-09-01 | 1 | -63/+0 |
* | Delete superfluous pci_bus.c files | Sebastian Huber | 2015-09-01 | 1 | -736/+0 |
* | Delete superfluous legacy.c files | Sebastian Huber | 2015-09-01 | 1 | -373/+0 |
* | Update to FreeBSD 9.3 | Sebastian Huber | 2015-02-13 | 1 | -1/+1 |
* | Update to FreeBSD 9.2 | Sebastian Huber | 2013-11-11 | 6 | -122/+210 |
* | Reduce divergence from FreeBSD sources | Sebastian Huber | 2013-11-11 | 2 | -10/+0 |
* | Rename rtems-bsd-config.h | Sebastian Huber | 2013-11-11 | 3 | -3/+3 |
| | | | | Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h. | ||||
* | Update to FreeBSD 8.4 | Sebastian Huber | 2013-11-04 | 3 | -18/+54 |
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 8 | -20/+1282 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | Move files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 3 | -0/+1652 |
