* | Delete superfluous pci_bus.c files | Sebastian Huber | 2015-09-01 | 1 | -736/+0 |
* | Update to FreeBSD 9.2 | Sebastian Huber | 2013-11-11 | 1 | -74/+73 |
* | Reduce divergence from FreeBSD sources | Sebastian Huber | 2013-11-11 | 1 | -8/+0 |
* | Rename rtems-bsd-config.h | Sebastian Huber | 2013-11-11 | 1 | -1/+1 |
| | | | | Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h. | ||||
* | Update to FreeBSD 8.4 | Sebastian Huber | 2013-11-04 | 1 | -7/+23 |
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -0/+729 |
Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. |
