* | user/zynqmp-rpu: Add load and debug informationHEADmaster | Kinsey Moore | 2024-04-11 | 1 | -8/+27 |
| | | | | | | This adds some information about loading the RPU TCMs from A53 u-boot and additional information about debugging the RPU within QEMU since it is non-standard. | ||||
* | user/zynqmp-rpu: Update boot suggestion | Kinsey Moore | 2024-02-26 | 1 | -2/+12 |
| | | | | | | Change the development suggestion for booting the R5 since the R5 u-boot is only minimally functional without significant development. This also adds caveats when booting the R5 cores from the A53. | ||||
* | user/bsps/arm: Add documentation for ZynqMP R5 BSP | Kinsey Moore | 2024-01-10 | 1 | -0/+66 |
| | | | | | This adds basic user documentation for running RTEMS on the Cortex-R5 processor on Xilinx Zynq Ultrascale+ MPSoC chips. | ||||
* | bsps/imxrt: Document GPIO CS pins for LPSPI | Christian Mauderer | 2023-11-28 | 1 | -0/+28 |
* | user/bsps/imxrt: Add new BSP variant | Christian Mauderer | 2023-07-24 | 1 | -36/+81 |
| | | | | | | | | | | | | | | | Add information about the new i.MXRT1166 BSP. Rework some parts that have been changed during or as preparation for that variant: * The BSP now adapts to the Chip variant. It's no longer necessary to overwrite the PLL settings in an application. * Improve documentation on how to adapt to different boards. * Add Update the i.MXRT chapter so that it represents the new i.MXRT1166 BSP. * Add information about mcux-sdk and how to handle it. | ||||
* | Update company name | Sebastian Huber | 2023-05-20 | 8 | -8/+8 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | user/bsps/arm: Fix a typo in the stm32h7 BSP documentation | Ruturaj Nanoti | 2023-03-15 | 1 | -1/+1 |
* | eng, user: update bsp_defaults to bspdefaults | Gedare Bloom | 2022-11-11 | 2 | -2/+2 |
* | user: Document arm/fvp BSP | Sebastian Huber | 2022-09-09 | 1 | -0/+39 |
| | | | | Close #4202. | ||||
* | user/arm/beagle: Fix image path after section change | Chris Johns | 2022-08-12 | 1 | -1/+1 |
* | versions: Update arm | Chris Johns | 2022-08-03 | 6 | -37/+43 |
| | | | | Updates #4695 | ||||
* | user/bsps/arm: Second Ethernet on i.MX | Christian Mauderer | 2022-06-09 | 1 | -0/+17 |
| | | | | | This adds information how to use a second Ethernet controller on the i.MX BSPs. | ||||
* | user: Document Zynq network | Sebastian Huber | 2022-06-01 | 1 | -1/+17 |
| | | | | Content is from rtems-libbsd/libbsd.txt with minor modifications. | ||||
* | user/bsps/arm: improve stm32h7 BSP description | Karel Gardas | 2022-06-01 | 1 | -16/+528 |
| | | | | | | | | | This patch adds kind of HOWTO to the stm32h7 BSP description. The howto discusses various tools from STM tool-chain and how to use them in order to configure board for RTEMS and to upload RTEMS application binary to the board. The patch also adds more supported boards to the table. Sponsored-By: Precidata | ||||
* | user/bsps/arm: remove dangling stm32h7 bsp page | Karel Gardas | 2022-04-06 | 1 | -32/+0 |
| | | | | | The page for STM32H7 BSP is twice here, so let's keep the one providing most information. | ||||
* | bsps/imxrt: Generate correctly aligned device tree | Christian Mauderer | 2022-02-21 | 1 | -2/+4 |
| | | | | | | The device tree has to be aligned correctly. rtems-bin2c has a new parameter for that. This patch uses this parameter to generate the right alignment and makes it more clear how to use the generated C file. | ||||
* | bsps/raspberrypi: Change firmware version, add SPI & I2C support | pranav | 2021-08-18 | 1 | -6/+45 |
* | user/imxrt: Add notes about problems with EVB | Christian Mauderer | 2021-07-29 | 1 | -0/+9 |
| | | | | | There are some possible problems with the i.MXRT1050 evaluation board. Make some notes about that in the BSP manual. | ||||
* | user/bsps/imxrt: Info about ARM PLL frequency | Christian Mauderer | 2021-07-02 | 1 | -0/+20 |
| | | | | Update #4180 | ||||
* | user/bsps/imxrt: Fix typo | Christian Mauderer | 2021-07-02 | 1 | -1/+1 |
* | bsps/imxrt: Remove superfluous options from dtc | Christian Mauderer | 2021-05-28 | 1 | -1/+1 |
| | | | | | | | | | | | The -@ option adds symbols that are used when applying an overlay. RTEMS doesn't support overlays or re-parsing of device trees. So the symbols only increase the size of the binary. The same is true for the padding. It would be useful if the device tree is changed during run time which is not supported in RTEMS. Update #4180 | ||||
* | user/bsps/arm/beagle: Update i2c initialization instructions | G S Niteesh Babu | 2021-04-22 | 1 | -13/+28 |
| | | | | | The new i2c driver in the beagle BSP uses FDT based initialization. This updates the documentation of the BSP about the same. | ||||
* | user/bsps: Add STM32H7 SDMMC driver | Christian Mauderer | 2021-04-01 | 1 | -0/+26 |
| | | | | Update #4372 | ||||
* | User/BSPs/Beagle: Add JTAG debugger section | Christian Mauderer | 2021-03-30 | 1 | -2/+65 |
* | user/bsps: Mention fixed console baud rate for zynq | Jan Sommer | 2021-03-16 | 1 | -0/+12 |
* | STM32H7 doc update | Robin Mueller | 2021-02-18 | 1 | -1/+17 |
* | user/bsp/imxrt: Information for custom FDT | Christian Mauderer | 2020-12-14 | 1 | -8/+38 |
| | | | | Update #4180 | ||||
* | user/bsps: Add imxrt | Christian Mauderer | 2020-11-20 | 1 | -0/+173 |
| | | | | Update #4180 | ||||
* | user: Add arm/stm32h7 | Sebastian Huber | 2020-10-27 | 2 | -0/+65 |
| | | | | Close #3910. | ||||
* | user: Rename files to match the chapter index | Sebastian Huber | 2020-10-27 | 2 | -0/+0 |
* | user/beagle: Add debug hardware mod | Chris Johns | 2020-10-19 | 1 | -0/+61 |
* | user: Add xilinx-zynq BSP details | Chris Johns | 2020-09-08 | 1 | -2/+112 |
* | user: Document arm/realview-pbx-a9 BSP | Sebastian Huber | 2020-07-02 | 1 | -2/+14 |
* | user/imx: Add i.MX6UL/ULL. | Christian Mauderer | 2020-04-15 | 1 | -3/+44 |
| | | | | Update #3869 | ||||
* | gdbarmsim: Remove all references to this deleted BSP family | Joel Sherrill | 2020-03-20 | 1 | -8/+0 |
| | | | | Updates #3611. | ||||
* | user/raspberrypi: Fix typo | G S Niteesh Babu | 2020-03-19 | 1 | -1/+1 |
| | | | | enable-uart should be enable_uart in config.txt | ||||
* | user: Add anchors to some BSPs. | Chris Johns | 2020-03-13 | 1 | -0/+6 |
* | doc/raspberrypi: Added instructions for raspberrypi | G S Niteesh | 2020-02-15 | 1 | -1/+110 |
| | | | | Added instructions to run examples on raspberrypi. | ||||
* | bsp/xen: Add information on Xen/ARM BSP | Jeff Kubascik | 2019-12-20 | 1 | -0/+79 |
| | | | | Add a README for the new xen bsp. | ||||
* | user: Mention xilinx-zynqmp BSP | Sebastian Huber | 2019-12-19 | 1 | -0/+8 |
| | | | | Close #3682. | ||||
* | bsps/beagle: update i2c section | Vijay Kumar Banerjee | 2019-09-26 | 1 | -3/+3 |
* | user/exe: Add link reference in device-tree | Vijay Kumar Banerjee | 2019-08-11 | 1 | -1/+1 |
* | user/bsps: Fix typo in beagle | Vijay Kumar Banerjee | 2019-08-08 | 1 | -2/+2 |
* | user/exe: Add Device Tree section | Vijay Kumar Banerjee | 2019-08-07 | 1 | -19/+2 |
* | user/bsps : Fix formatting and typo in arm/beagle | Vijay Kumar Banerjee | 2019-07-27 | 1 | -18/+37 |
* | user/bsps : Add documentation for Beagle | Vijay Kumar Banerjee | 2019-07-20 | 1 | -2/+89 |
* | user: Split the ARM BSPs source into separate files. | Chris Johns | 2019-07-12 | 19 | -0/+438 |
