* | bsps/imxrt: Remove superfluous options from dtc | Christian Mauderer | 2021-05-28 | 1 | -1/+1 |
| | | | | | | | | | | | The -@ option adds symbols that are used when applying an overlay. RTEMS doesn't support overlays or re-parsing of device trees. So the symbols only increase the size of the binary. The same is true for the padding. It would be useful if the device tree is changed during run time which is not supported in RTEMS. Update #4180 | ||||
* | user/bsps/arm/beagle: Update i2c initialization instructions | G S Niteesh Babu | 2021-04-22 | 1 | -13/+28 |
| | | | | | The new i2c driver in the beagle BSP uses FDT based initialization. This updates the documentation of the BSP about the same. | ||||
* | user/bsps: Add STM32H7 SDMMC driver | Christian Mauderer | 2021-04-01 | 1 | -0/+26 |
| | | | | Update #4372 | ||||
* | User/BSPs/Beagle: Add JTAG debugger section | Christian Mauderer | 2021-03-30 | 1 | -2/+65 |
* | user/bsps: Mention fixed console baud rate for zynq | Jan Sommer | 2021-03-16 | 1 | -0/+12 |
* | STM32H7 doc update | Robin Mueller | 2021-02-18 | 1 | -1/+17 |
* | user/bsp/imxrt: Information for custom FDT | Christian Mauderer | 2020-12-14 | 1 | -8/+38 |
| | | | | Update #4180 | ||||
* | user/bsps: Add imxrt | Christian Mauderer | 2020-11-20 | 1 | -0/+173 |
| | | | | Update #4180 | ||||
* | user: Add arm/stm32h7 | Sebastian Huber | 2020-10-27 | 2 | -0/+65 |
| | | | | Close #3910. | ||||
* | user: Rename files to match the chapter index | Sebastian Huber | 2020-10-27 | 2 | -0/+0 |
* | user/beagle: Add debug hardware mod | Chris Johns | 2020-10-19 | 1 | -0/+61 |
* | user: Add xilinx-zynq BSP details | Chris Johns | 2020-09-08 | 1 | -2/+112 |
* | user: Document arm/realview-pbx-a9 BSP | Sebastian Huber | 2020-07-02 | 1 | -2/+14 |
* | user/imx: Add i.MX6UL/ULL. | Christian Mauderer | 2020-04-15 | 1 | -3/+44 |
| | | | | Update #3869 | ||||
* | gdbarmsim: Remove all references to this deleted BSP family | Joel Sherrill | 2020-03-20 | 1 | -8/+0 |
| | | | | Updates #3611. | ||||
* | user/raspberrypi: Fix typo | G S Niteesh Babu | 2020-03-19 | 1 | -1/+1 |
| | | | | enable-uart should be enable_uart in config.txt | ||||
* | user: Add anchors to some BSPs. | Chris Johns | 2020-03-13 | 1 | -0/+6 |
* | doc/raspberrypi: Added instructions for raspberrypi | G S Niteesh | 2020-02-15 | 1 | -1/+110 |
| | | | | Added instructions to run examples on raspberrypi. | ||||
* | bsp/xen: Add information on Xen/ARM BSP | Jeff Kubascik | 2019-12-20 | 1 | -0/+79 |
| | | | | Add a README for the new xen bsp. | ||||
* | user: Mention xilinx-zynqmp BSP | Sebastian Huber | 2019-12-19 | 1 | -0/+8 |
| | | | | Close #3682. | ||||
* | bsps/beagle: update i2c section | Vijay Kumar Banerjee | 2019-09-26 | 1 | -3/+3 |
* | user/exe: Add link reference in device-tree | Vijay Kumar Banerjee | 2019-08-11 | 1 | -1/+1 |
* | user/bsps: Fix typo in beagle | Vijay Kumar Banerjee | 2019-08-08 | 1 | -2/+2 |
* | user/exe: Add Device Tree section | Vijay Kumar Banerjee | 2019-08-07 | 1 | -19/+2 |
* | user/bsps : Fix formatting and typo in arm/beagle | Vijay Kumar Banerjee | 2019-07-27 | 1 | -18/+37 |
* | user/bsps : Add documentation for Beagle | Vijay Kumar Banerjee | 2019-07-20 | 1 | -2/+89 |
* | user: Split the ARM BSPs source into separate files. | Chris Johns | 2019-07-12 | 19 | -0/+438 |
