#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
- Add support for architecure sections that can be handled by the
architecture back end.
- Add trampoline/fixup support for PowerPC. This means the PowerPC
now supports large memory loading of applications.
- Add a bit allocator to manage small block based regions of memory.
- Add small data (sdata/sbss) support for the PowerPC. The support
makes the linker allocated small data region of memory a global
resource available to libdl loaded object files.
Updates #3687
Updates #3685
This has been tested on SPARC, i386, PowerPC and ARM.
Closes #2767.
