2020-09-17 | validation: rtems_task_construct() errors | Sebastian Huber | |
This is the first test case generated from a specification item in the rtems-central repository. Update #3959. | |||
2020-09-17 | validation: Add general purpose test suite | Sebastian Huber | |
Add a general purpose test suite for validation tests. This is the first test suite generated from a specification item in the rtems-central repository. Update #3959. | |||
2020-09-17 | rtems: Add rtems_task_construct() | Sebastian Huber | |
In contrast to rtems_task_create() this function constructs a task with a user-provided task storage area. The new directive uses a configuration structure instead of individual parameters. Add RTEMS_TASK_STORAGE_SIZE() to calculate the recommended size of a task storage area based on the task attributes and the size dedicated to the task stack and thread-local storage. This macro may allow future extensions without breaking the API. Add application configuration option CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE to adjust RTEMS Workspace size estimate. Update #3959. | |||
2020-09-17 | CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE | Sebastian Huber | |
Add this application configuration option. This configuration option can be used to reserve space for the dynamic linking of modules with thread-local storage objects. Add RTEMS_TASK_STORAGE_ALIGNMENT to define the minium alignment of a thread-local storage size. Update #4074. | |||
2020-09-14 | irqs01/smpirqs01: New tests | Sebastian Huber | |
Close #4034. | |||
2020-09-14 | build: Alternative build system based on waf | Sebastian Huber | |
Update #3818. | |||
2020-09-11 | Remove tmoverhd which existed to produce the obsolete coverhd.h | Joel Sherrill | |
Closes #4040. | |||
2020-09-10 | spintrcritical08: Increase clock tick interval | Sebastian Huber | |
On some simulators, a clock tick interval of 1ms seems to be too short. For example, the test failed on sparc/erc32 using the SIS. | |||
2020-08-31 | score: Add <rtems/score/freechainimpl.h> | Sebastian Huber | |
Hide implementation details. Update #3959. | |||
2020-08-31 | rtems: Add _RTEMS_Name_to_id() | Sebastian Huber | |
Simplify object name to identifier directives. Using _RTEMS_Name_to_id() to implement the directives enables a tail call optimization. Change license to BSD-2-Clause according to file history. Update #3053. | |||
2020-08-21 | spintrcritical22: Use right thread wait flags | Sebastian Huber | |
2020-08-21 | spintrcritical16: Use right thread wait flags | Sebastian Huber | |
2020-08-21 | mp03: Include missing header file | Sebastian Huber | |
2020-08-20 | spintrcritical23: Fix unused variable warnings | Sebastian Huber | |
2020-08-20 | sp37: Fix unused variable warnings | Sebastian Huber | |
2020-08-20 | psxkey01: Fix configuration | Aschref Ben Thabet | |
Key_ID array must have the right size, it shall have a value greater than zero. Note: In Standard C and C++, zero-size array is not allowed.. | |||
2020-08-18 | libtest: Add T_push_plan() and T_pop_plan() | Sebastian Huber | |
Update #3199. | |||
2020-08-18 | libtest: Change T_step() and T_assert_step() | Sebastian Huber | |
Normally, the expected test step must be a compile time constant. Allow variable expected test steps for the T_step() and T_assert_step(). This can be used for parameterized test loops with individual fixtures. Remove the ability to use custom failure messages due to some implementation constraints. Update #3199. | |||
2020-08-18 | libtest: Add fixture steps | Sebastian Huber | |
Support a new test plan for each nested fixture. Update #3199. | |||
2020-08-18 | libtest: Change fixture scope method | Sebastian Huber | |
Return the produced character count. There is no need for a NUL termination. Update #3199. | |||
2020-08-11 | spintrcritical23: Restore runner priority | Sebastian Huber | |
2020-08-11 | libtests/dl10: Delete unused functions | Aschref Ben Thabet | |
2020-08-11 | libtest: Add T_thread_switch_record() | Sebastian Huber | |
Add support to record thread switch events. This can be used to check that a blocking operation results in the expected sequence of thread switches. Update #3199. | |||
2020-08-06 | libtest: Fix T_interrupt_test() in SMP configs | Sebastian Huber | |
Update #3199. | |||
2020-08-05 | psxhdrs/strncpy/stpncpy: Fix string turncation warning | Aschref Ben Thabet | |
Since we need to test the strncpy function, using a character array with a fixed array size in this case in place of character pointer can avoid the string turncation warning. | |||
2020-08-04 | smpschededf02: Document reset() function | Sebastian Huber | |
2020-07-30 | psxhdrs/strncat: Fix string truncation warning | Aschref Ben Thabet | |
2020-07-24 | spmisc01: Include missing header file | Sebastian Huber | |
Update #4032. | |||
2020-07-24 | score: Add RTEMS_WEAK | Sebastian Huber | |
Update #4032. | |||
2020-07-23 | spintrcritical_support: Remove | Sebastian Huber | |
This test support was replaced by T_interrupt_test() is no longer used. | |||
2020-07-23 | spintrcritical24: Use T_interrupt_test() | Sebastian Huber | |
2020-07-23 | spintrcritical23: Use T_interrupt_test() | Sebastian Huber | |
2020-07-23 | spintrcritical22: Use T_interrupt_test() | Sebastian Huber | |
2020-07-23 | spintrcritical21: Use T_interrupt_test() | Sebastian Huber | |
2020-07-23 | spintrcritical20: Use T_interrupt_test() | Sebastian Huber | |
2020-07-23 | spintrcritical18: Use T_interrupt_test() | Sebastian Huber | |
2020-07-23 | spintrcritical16: Use T_interrupt_test() | Sebastian Huber | |
2020-07-23 | spintrcritical15: Use T_interrupt_test() | Sebastian Huber | |
2020-07-23 | spintrcritical13/14: Use T_interrupt_test() | Sebastian Huber | |
2020-07-23 | spintrcritical11/12: Use T_interrupt_test() | Sebastian Huber | |
2020-07-23 | spintrcritical10: Use T_interrupt_test() | Sebastian Huber | |
2020-07-23 | spintrcritical09: Use T_interrupt_test() | Sebastian Huber | |
2020-07-23 | spintrcritical08: Use T_interrupt_test() | Sebastian Huber | |
2020-07-23 | spintrcritical06/spintrcritical07: Remove tests | Sebastian Huber | |
These two tests check conditions which no longer exist in the thread queue implementation. The are obsolete since the change to use red-black trees for the priority queues. | |||
2020-07-23 | spintrcritical01/2/3/4/5: Use T_interrupt_test() | Sebastian Huber | |
2020-07-23 | psxintrcritical01: Use T_interrupt_test() | Sebastian Huber | |
2020-07-23 | libtest: Add T_interrupt_test() | Sebastian Huber | |
Update #3199. | |||
2020-07-23 | libtest: Make check message optional | Sebastian Huber | |
This macro magic is in line with C11 and C++11, but limits the maximum count of arguments. Update #3199. | |||
2020-07-23 | libtest: Add push/pop fixture support | Sebastian Huber | |
Update #3199. | |||
2020-07-23 | libtest: Support custom scope messages via fixture | Sebastian Huber | |
Update #3199. |
