Add a simplified path evaluation function IMFS_eval_path_devfs() for a
device only IMFS configuration.
The code size can be further reduced by the application if it disables
the support for legacy IO drivers via:
#define CONFIGURE_IMFS_DISABLE_MKNOD
#define CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE
Obsolete CONFIGURE_MAXIMUM_DEVICES. Remove BSP_MAXIMUM_DEVICES.
Update #3894.
Update #3898.
Update #3753.
This configuration is superfluous in these tests.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
PR 1654/testing
* deviceio01/init.c, deviceio01/deviceio01.doc,
deviceio01/deviceio01.scn, deviceio01/test_driver.c,
deviceio01/test_driver.h, deviceio01/Makefile.am: New test added.
* Makefile.am, configure.ac: Changes to added above test.
* tar02/init.c, tar02/tar02.scn: New test case added: IMFS_dump().
