2018-11-16 | glossary.rst: Fix grammar errors (GCI 2018) | Aneendya | |
2018-10-19 | Update the copyright year. | Chris Johns | |
2018-08-21 | build: Fix indexing so it works on HTML and PDF. | Chris Johns | |
- Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | |||
2017-11-12 | Add indexes to all documents. | Chris Johns | |
Update #3229. | |||
2017-11-09 | Change RTEMS version to 5 | Sebastian Huber | |
Update #3220. | |||
2017-09-04 | Eclipse: Fix TOC and glossary licence comment. | Chris Johns | |
2017-08-11 | Update copyright notices. | Chris Johns | |
2017-03-27 | waf: Cleaner formatting to see the importing. | Chris Johns | |
2017-03-20 | Use a single top level version number. | Chris Johns | |
2017-01-11 | Update document titles for consistency | Joel Sherrill | |
2016-12-21 | Update version/revision to 4.11.99 | Sebastian Huber | |
2016-11-09 | eclipse: Fix heading levels. | Chris Johns | |
2016-05-20 | Add Eclipse user manual for RTEMS. | Chris Johns | |
