Peter requested this after reviewing the converted content. He
noted that it was a nit but he had consistently used his middle
initial in all academic settings and wanted to be consistent.
Python 3 produces an error if indentation is mixed tabs and spaces.
This work was part of GCI 2018.
Redraw images/eng/Git-personalrepo as SVG and PNG with a better
color palette.
Converted https://devel.rtems.org/wiki/Developer/Git/Users
to Rest, and TBDs and wiki TODOs into comments. Also changed http
links to https (the ones that are possible), corrected typos, updated
learning resources links and added formattings.
Converted https://devel.rtems.org/wiki/Developer/Git/Committers
links to https (the ones that are possible), corrected some typos,
created a folder for eng images and added some formatting.
Converted https://devel.rtems.org/wiki/Developer/Coding/80_characters_per_line
to Rest, and TBDs into comments.
Convert text to a table, TBDs into comments and add missing
formatting.
Thanks to Scott Zemerick <scott.zemerick@tmctechnologies.com> for
the analysis and ideas that led to this.
All of the redrawings were made by me except images/c_user/states which
was made by LukaMag. This patch serves to update all the images.
Close #3636.
In the RTEMS POSIX 1003.1 Compliance Guide it says:
The following methods and variables in <sys/times.h> are supported:
- times()
- utimes()
But according to the official POSIX Specifications
http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/sys_times.h.html,
<sys/times.h> only declares times(), and utimes() is decleared by
<sys/time.h> (notice that it's time, not times) according to
http://pubs.opengroup.org/onlinepubs/9699919799/functions/utimensat.html
and http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/sys_time.h.html.
This patch fixes this error.
This is kind of a dual-check since it checks for the version while simultaneously
checking to see if Sphinx exists on the system.
Changed the error messages to be clear on the error and removed a reference to
version which cannot be set due to the check failure.
Reported by: Shashvat Jain
Add and update Device and Class Specific APIs in
POSIX Users Guide.
Add and update Prototypes to Input and Output APIs in
POSIX Users Guide.
Add Prototypes to Memory Management APIs in POSIX Users Guide.
Add Prototypes to System Database APIs in POSIX Users Guide.
Add Prototypes to Thread Cancellation APIs.
Specific Service APIs
Close #3603.
This content originated as an email response from Jiri Gaisler
to Joel Sherrill in response to a question.
File was missed in previous commit.
Fixed tables, typos, redrawn images and converted ASCII art to ditaa
and PNG, and improved the overall format.
Closes #3567.
Leaving notes for follow up as a GCI 2018 task.
This content was originally at https://www.sics.se/~psm/sparcstack.html
and is currently only available via the Wayback Machine. Peter kindly gave
permission to include it with the RTEMS Documentation. This initial commit
is a cut and paste with minimal edits. Edits are needed to ensure proper
formatting and the figures need to be made to look correct in the Rest
formatted output.
Closes #3416.
Spaces and other specical characters in pathnames break builds of any
software packages using GNU make.
All of the GNU tools and RTEMS use make and this breaks builds. This
is a long standing known issue with GNU make, which can't handle spaces
in pathnames:
https://savannah.gnu.org/bugs/?712
Probably closes #3450.
Update #3584.
Update #3587.
Update #3589.
