line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
do
echo $b
# echo $g
-i $b
done
PR 1738/bsps
* clock/clock.c, include/bsp.h, network/network.c: system clock driver
programs the PIT w/o assuming the CPU clock frequency being a power
of two.
* clock/clock.c, include/bsp.h: Rename BSP specific idle thread to
bsp_idle_thread.
* clock/clock.c, include/bsp.h: Make bsp idle thread names match.
* clock/clock.c, include/bsp.h: Change prototype of IDLE thread to
consistently return void * and take a uintptr_t argument.
* Makefile.am, configure.ac, include/bsp.h, startup/bspstart.c: Rename
existing bsp_reset() to bsp_sysReset() since the prototype did not
match the standard one. Add standard bsp_reset().
* startup/bspreset.c: New file.
* include/bsp.h: Remove unnecessary boilerplate comments.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* clock/clock.c, include/bsp.h: Correct prototype of idle thread. Eric
Norum pointed out this was wrong.
* clock/clock.c, include/bsp.h, startup/bspstart.c: Eliminate copies of
the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* include/bsp.h, startup/bspstart.c: Moved most of the remaining CPU
Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* clock/clock.c, console/console.c, include/bsp.h, include/coverhd.h,
include/tm27.h, network/network.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/init5282.c, startup/linkcmds,
timer/timer.c: Correct license URL and/or fix mistake in copyright
notice. Both of these mistakes appear to be from code submitted after
these changes were made previously.
PR 1227/bsps
* include/bsp.h: Remove MAX_LONG_TEST_DURATION and
MAX_SHORT_TEST_DURATION. They are obsolete and unused.
* include/bsp.h: New header guard.
Improve in-line assembly.
Add some more system calls.
* console/console.c, include/bsp.h, network/network.c,
startup/bspstart.c: Remove obsolete fixed size types.
mechanism for applications to find a free level/priority.
