* | Added support for RISCV32 systems with CLINT/PLIC | Jiri Gaisler | 2020-12-15 | 1 | -1/+2 |
* | Added emulation of GR740 SOC2.25 | Jiri Gaisler | 2020-12-01 | 1 | -1/+1 |
| | | | | * Only limited functionality with standard peripherals | ||||
* | Make grlib IP cores more modular and move them to grlib.c | Jiri Gaisler | 2020-12-01 | 1 | -26/+13 |
* | Add networking support using host tap device2.23 | Jiri Gaisler | 2020-10-28 | 1 | -6/+7 |
| | | | | | | * Emulation of GRETH 10/100 Mbit MAC and PHY * Supported only on linux | ||||
* | Add -rt option to synch sim to wall time | Jiri Gaisler | 2020-10-25 | 1 | -0/+18 |
| | | | | | * Active during cpu power-down to avoid run-away sim time. Useful for interactive applications. | ||||
* | Fix incorrect operation on big-endian hosts | Jiri Gaisler | 2020-02-29 | 1 | -3/+3 |
* | Avoid reserved word sparc on SPARC hosts | Jiri Gaisler | 2020-02-26 | 1 | -1/+1 |
* | Cross-platform support for async gdb break (ctrl-c) | Jiri Gaisler | 2019-11-14 | 1 | -37/+25 |
* | Support building on MinGW-W64/MSYS22.19 | Jiri Gaisler | 2019-11-09 | 1 | -6/+12 |
| | | | | * Depends on MinGW64-readline to build | ||||
* | Improve gdb watchpoint handling | Jiri Gaisler | 2019-11-08 | 1 | -0/+2 |
| | | | | | * show old/new values * stop at correct instruction | ||||
* | Added support for gdb hw break/watchpoints | Jiri Gaisler | 2019-11-02 | 1 | -17/+13 |
* | Fix C formatting with indent | Jiri Gaisler | 2019-06-11 | 1 | -938/+1206 |
* | Silence warnings when compiled with LLVM | Jiri Gaisler | 2019-06-11 | 1 | -15/+9 |
* | Made L1 cache optional through --enable-l1cache | Jiri Gaisler | 2019-05-28 | 1 | -9/+23 |
| | | | | | | | * Removed stale config.h * Updated autoconf script with relevant checks * Re-implemented leon3/grlib timer with less events * Bumped version to 2.15 | ||||
* | Add emulated L1 cache to SMP configurations | Jiri Gaisler | 2019-05-27 | 1 | -4/+17 |
| | | | | * Also improve timing accuracy for certain instructions | ||||
* | Standalone sis - initial commit | Jiri Gaisler | 2019-05-14 | 1 | -0/+1362 |
