brains GmbH.
Use the item UID converted to CamelCase for Doxygen group names and
testsuite names.
Update #3716.
The test source code is generated from specification items
by the "./spec2modules.py" script contained in the
git://git.rtems.org/rtems-central.git Git repository.
Please read the "How-To" section in the "Software Requirements Engineering"
chapter of the RTEMS Software Engineering manual to get more information about
the process.
Update #3716.
Move the transition map members of the test context to a dedicated
structure. Move the transition variant pre-condition prepare, action,
and post-condition checks to a separate function to reduce the
indentation level and allow skipping of transition variants.
Add a library for support functions used by validation tests. Rename
tc-support.* to tx-support.* since this file does not contain test
cases.
In the action requirements, some pre-conditions are not applicable
depending on the state of other pre-conditions. There is no particular
order in the pre-conditions, so we have to check the N/A status
individually.
Use a common wording for the tests. Use the new templates for action
requirements described in the RTEMS Software Engineering manual.
Unify code sections across tests.
