Close #3418.
upgrade to that version.
Close #3387.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
for details.
* configure.ac: Rework. Make package a host compiled package.
* Makefile.am: Ditto.
* configure.ac: Reflect having moved to testsuites/.
* configure.in: Remove.
