call to printk.
Updates #3170.
This service was marked as deprecated long prior to the 4.11 release
series and is now being removed.
closes #2676.
Notepads where a feature of RTEMS' tasks that simply functioned in
the same way as POSIX keys or threaded local storage (TLS). They were
introduced well before per task variables, which are also deprecated,
and were barely used in favor of their POSIX alternatives.
In addition to their scarce usage, Notepads took up unnecessary memory.
For each task:
- 16 32-bit integers were allocated.
- A total of 64 bytes per task per thread.
This is especially critical in low memory and safety-critical applications.
They are also defined as uint32_t, and therefore are not guaranteed to
hold a pointer.
Lastly, they are not portable solutions for SMP and uniprocessor systems,
like POSIX keys and TLS.
updates #2493.
Hi,
Adding test documentation...
for details.
PR 1589/build
* tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am,
tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am,
tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am,
tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am,
tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am,
tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am,
tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am,
tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am,
tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am,
tm28/Makefile.am, tm29/Makefile.am, tm30/Makefile.am,
tmck/Makefile.am, tmoverhd/Makefile.am: Remove obsolete optional
manager capability.
* tmoverhd/testtask.c: Apply RTEMS_GCC_NOWARN_USED.
* tmoverhd/dumrtems.h: Rework undef/define cascade.
Add RTEMS_GCC_NOWARN_USED.
* tmoverhd/system.h: Add prototype for Empty_directive();
* tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c,
tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c,
tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm16/task1.c,
tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c, tm21/task1.c,
tm23/task1.c, tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c,
tm28/task1.c, tm29/task1.c, tmoverhd/testtask.c: Run all tests
successfully with maxixum number of priorities as 16 instead of 256.
This was done by temporarily modifying the score priority.h maximum.
This allowed testing of all API code to ensure that it worked
properly with a reduced number of priorities. Most modifications were
to switch from hard-coded maximum to using the API provided methods
to determine maximum number of priority levels.
* tm01/Makefile.am, tm01/task1.c, tm02/Makefile.am, tm02/task1.c,
tm03/Makefile.am, tm03/task1.c, tm04/Makefile.am, tm04/task1.c,
tm05/Makefile.am, tm05/task1.c, tm06/Makefile.am, tm06/task1.c,
tm07/Makefile.am, tm07/task1.c, tm08/Makefile.am, tm08/task1.c,
tm09/Makefile.am, tm09/task1.c, tm10/Makefile.am, tm10/task1.c,
tm11/Makefile.am, tm11/task1.c, tm12/Makefile.am, tm12/task1.c,
tm13/Makefile.am, tm13/task1.c, tm14/Makefile.am, tm14/task1.c,
tm15/Makefile.am, tm15/task1.c, tm16/Makefile.am, tm16/task1.c,
tm17/Makefile.am, tm17/task1.c, tm18/Makefile.am, tm18/task1.c,
tm19/Makefile.am, tm19/task1.c, tm20/Makefile.am, tm20/task1.c,
tm21/Makefile.am, tm21/task1.c, tm22/Makefile.am, tm22/task1.c,
tm23/Makefile.am, tm23/task1.c, tm24/Makefile.am, tm24/task1.c,
tm25/Makefile.am, tm25/task1.c, tm26/Makefile.am, tm26/task1.c,
tm27/Makefile.am, tm27/task1.c, tm28/Makefile.am, tm28/task1.c,
tm29/Makefile.am, tm29/task1.c, tmck/Makefile.am, tmck/task1.c,
tmoverhd/Makefile.am, tmoverhd/testtask.c: Eliminate empty function
from every benchmark timer driver. Fix spelling.
tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c,
tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c,
tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c,
tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmck/task1.c,
tmoverhd/testtask.c: Rename timer driver methods to follow RTEMS
programming conventions.
* tmoverhd/dumrtems.h: Refactored and renamed initialization routines
to rtems_initialize_data_structures, rtems_initialize_before_drivers,
rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
tmoverhd/testtask.c: Change TEST_INIT to CONFIGURE_INIT. Make
tmacros.h available to all POSIX tests. Add a clock_settime case for
< 1988.
* tmoverhd/testtask.c: Spacing and remove call to obsolete
rtems_initialize_executive().
* tmoverhd/testtask.c: Move interrupt_stack_size field from CPU Table
to Configuration Table. Eliminate CPU Table from all ports. Delete
references to CPU Table in all forms.
* tm05/Makefile.am, tm06/Makefile.am, tm07/Makefile.am,
tm08/Makefile.am, tm09/Makefile.am, tm10/Makefile.am,
tm11/Makefile.am, tm12/Makefile.am, tm13/Makefile.am,
tm14/Makefile.am, tm15/Makefile.am, tm16/Makefile.am,
tm17/Makefile.am, tm18/Makefile.am, tm19/Makefile.am,
tm20/Makefile.am, tm22/Makefile.am, tm23/Makefile.am,
tm24/Makefile.am, tm25/Makefile.am, tm26/Makefile.am,
tm27/Makefile.am, tm28/Makefile.am, tm29/Makefile.am,
tmck/Makefile.am, tmoverhd/Makefile.am: Add optional managers to
Makefiles. Clean up test cases so last output line follows END OF
pattern. Make sure test case all run. All tests appeared ok on sis.
* tm02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm13/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm14/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm15/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm16/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm17/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm18/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm19/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm20/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm21/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm22/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm23/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm24/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm25/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm26/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm27/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm28/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm29/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tmck/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tmoverhd/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* include/timesys.h, tm01/task1.c, tm02/task1.c, tm03/task1.c,
tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c,
tm08/task1.c, tm09/task1.c, tm10/task1.c, tm11/task1.c,
tm16/task1.c, tm17/task1.c, tm18/task1.c, tm20/task1.c,
tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c,
tm29/task1.c, tmck/task1.c, tmoverhd/testtask.c: Convert to using
c99 fixed size types.
* tm01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* tm02/Makefile.am: Ditto.
* tm03/Makefile.am: Ditto.
* tm04/Makefile.am: Ditto.
* tm05/Makefile.am: Ditto.
* tm06/Makefile.am: Ditto.
* tm07/Makefile.am: Ditto.
* tm08/Makefile.am: Ditto.
* tm09/Makefile.am: Ditto.
* tm10/Makefile.am: Ditto.
* tm11/Makefile.am: Ditto.
* tm12/Makefile.am: Ditto.
* tm13/Makefile.am: Ditto.
* tm14/Makefile.am: Ditto.
* tm15/Makefile.am: Ditto.
* tm16/Makefile.am: Ditto.
* tm17/Makefile.am: Ditto.
* tm18/Makefile.am: Ditto.
* tm19/Makefile.am: Ditto.
* tm20/Makefile.am: Ditto.
* tm21/Makefile.am: Ditto.
* tm22/Makefile.am: Ditto.
* tm23/Makefile.am: Ditto.
* tm24/Makefile.am: Ditto.
* tm25/Makefile.am: Ditto.
* tm26/Makefile.am: Ditto.
* tm27/Makefile.am: Ditto.
* tm28/Makefile.am: Ditto.
* tm29/Makefile.am: Ditto.
* tmck/Makefile.am: Ditto.
* tmoverhd/Makefile.am: Ditto.
* include/Makefile.am: Reformat.
* tm01/Makefile.am: Remove all-local: $(ARCH).
* tm02/Makefile.am: Remove all-local: $(ARCH).
* tm03/Makefile.am: Remove all-local: $(ARCH).
* tm04/Makefile.am: Remove all-local: $(ARCH).
* tm05/Makefile.am: Remove all-local: $(ARCH).
* tm06/Makefile.am: Remove all-local: $(ARCH).
* tm07/Makefile.am: Remove all-local: $(ARCH).
* tm08/Makefile.am: Remove all-local: $(ARCH).
* tm09/Makefile.am: Remove all-local: $(ARCH).
* tm10/Makefile.am: Remove all-local: $(ARCH).
* tm11/Makefile.am: Remove all-local: $(ARCH).
* tm12/Makefile.am: Remove all-local: $(ARCH).
* tm13/Makefile.am: Remove all-local: $(ARCH).
* tm14/Makefile.am: Remove all-local: $(ARCH).
* tm15/Makefile.am: Remove all-local: $(ARCH).
* tm16/Makefile.am: Remove all-local: $(ARCH).
* tm17/Makefile.am: Remove all-local: $(ARCH).
* tm18/Makefile.am: Remove all-local: $(ARCH).
* tm19/Makefile.am: Remove all-local: $(ARCH).
* tm20/Makefile.am: Remove all-local: $(ARCH).
* tm21/Makefile.am: Remove all-local: $(ARCH).
* tm22/Makefile.am: Remove all-local: $(ARCH).
* tm23/Makefile.am: Remove all-local: $(ARCH).
* tm24/Makefile.am: Remove all-local: $(ARCH).
* tm25/Makefile.am: Remove all-local: $(ARCH).
* tm26/Makefile.am: Remove all-local: $(ARCH).
* tm27/Makefile.am: Remove all-local: $(ARCH).
* tm28/Makefile.am: Remove all-local: $(ARCH).
* tm29/Makefile.am: Remove all-local: $(ARCH).
* tmck/Makefile.am: Remove all-local: $(ARCH).
* tmoverhd/Makefile.am: Remove all-local: $(ARCH).
* include/timesys.h, tm01/system.h, tm01/task1.c, tm01/tm01.doc,
tm02/system.h, tm02/task1.c, tm02/tm02.doc, tm03/system.h,
tm03/task1.c, tm03/tm03.doc, tm04/system.h, tm04/task1.c,
tm04/tm04.doc, tm05/system.h, tm05/task1.c, tm05/tm05.doc,
tm06/system.h, tm06/task1.c, tm06/tm06.doc, tm07/system.h,
tm07/task1.c, tm07/tm07.doc, tm08/system.h, tm08/task1.c,
tm08/tm08.doc, tm09/system.h, tm09/task1.c, tm09/tm09.doc,
tm10/system.h, tm10/task1.c, tm10/tm10.doc, tm11/system.h,
tm11/task1.c, tm11/tm11.doc, tm12/system.h, tm12/task1.c,
tm12/tm12.doc, tm13/system.h, tm13/task1.c, tm13/tm13.doc,
tm14/system.h, tm14/task1.c, tm14/tm14.doc, tm15/system.h,
tm15/task1.c, tm15/tm15.doc, tm16/system.h, tm16/task1.c,
tm16/tm16.doc, tm17/system.h, tm17/task1.c, tm17/tm17.doc,
tm18/system.h, tm18/task1.c, tm18/tm18.doc, tm19/system.h,
tm19/task1.c, tm19/tm19.doc, tm20/system.h, tm20/task1.c,
tm20/tm20.doc, tm21/system.h, tm21/task1.c, tm21/tm21.doc,
tm22/system.h, tm22/task1.c, tm22/tm22.doc, tm23/system.h,
tm23/task1.c, tm23/tm23.doc, tm24/system.h, tm24/task1.c,
tm24/tm24.doc, tm25/system.h, tm25/task1.c, tm25/tm25.doc,
tm26/fptest.h, tm26/system.h, tm26/task1.c, tm26/tm26.doc,
tm27/system.h, tm27/task1.c, tm27/tm27.doc, tm28/system.h,
tm28/task1.c, tm28/tm28.doc, tm29/system.h, tm29/task1.c,
tm29/tm29.doc, tmck/system.h, tmck/task1.c, tmck/tmck.doc,
tmoverhd/dumrtems.h, tmoverhd/empty.c, tmoverhd/system.h,
tmoverhd/testtask.c, tmoverhd/tmoverhd.doc: URL for license changed.
tm01/Makefile.am: Reflect having moved automake.
tm02/Makefile.am: Reflect having moved automake.
tm03/Makefile.am: Reflect having moved automake.
tm04/Makefile.am: Reflect having moved automake.
tm05/Makefile.am: Reflect having moved automake.
tm06/Makefile.am: Reflect having moved automake.
tm07/Makefile.am: Reflect having moved automake.
tm08/Makefile.am: Reflect having moved automake.
tm09/Makefile.am: Reflect having moved automake.
tm10/Makefile.am: Reflect having moved automake.
tm11/Makefile.am: Reflect having moved automake.
tm12/Makefile.am: Reflect having moved automake.
tm13/Makefile.am: Reflect having moved automake.
tm14/Makefile.am: Reflect having moved automake.
tm15/Makefile.am: Reflect having moved automake.
tm16/Makefile.am: Reflect having moved automake.
tm17/Makefile.am: Reflect having moved automake.
tm18/Makefile.am: Reflect having moved automake.
tm19/Makefile.am: Reflect having moved automake.
tm20/Makefile.am: Reflect having moved automake.
tm21/Makefile.am: Reflect having moved automake.
tm22/Makefile.am: Reflect having moved automake.
tm23/Makefile.am: Reflect having moved automake.
tm24/Makefile.am: Reflect having moved automake.
tm25/Makefile.am: Reflect having moved automake.
tm26/Makefile.am: Reflect having moved automake.
tm27/Makefile.am: Reflect having moved automake.
tm28/Makefile.am: Reflect having moved automake.
tm29/Makefile.am: Reflect having moved automake.
tmck/Makefile.am: Reflect having moved automake.
tmoverhd/Makefile.am: Reflect having moved automake.
