This avoids a dependency on the non-standard libxml2 module.
This avoids a dependency on the non-standard libxml2 module. Reorder
test cases according to expected performance.
brains GmbH.
Updates #3053.
+ include
+ tmck
+ tmfine01
+ tmonetoone
+ tmtimer01
Updates #3053.
Updates #3053.
Updates #4625.
MrsP semaphores are a generalization of the priority ceiling semaphores
for SMP configurations. Priority ceiling semaphores are required to use
the priority task wait queue discipline. Require this discipline also
for MrsP semaphores.
Close #4347.
Rename this header file to later move <t.h> to <rtems/test.h>. The main
feature provided by <rtems/test-info.h> is the output of standard test
information which is consumed by the RTEMS Tester.
Update #3199.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
The MrsP semaphore implementation predates the addition of
self-contained synchronization objects. At this time, the potential
memory reduction was justified considering the more complex
configuration and additional use of the workspace. With the
availability of self-contained synchronization options, e.g. POSIX
mutexes, this is no longer justified. Memory constrained applications
should use the self-contained synchronization objects. Remove the
CONFIGURE_MAXIMUM_MRSP_SEMAPHORES configuration option. This has only an
impact on applications which use SMP and a large number of scheduler
instances.
Update #3833.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Reduce test context size in non-SMP configurations.
Close #3200.
call to printk.
Updates #3170.
Update #2674.
Update #3112.
Update #3113.
Update #3114.
Update #3115.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Add _CPU_Get_current_per_CPU_control() on SMP configurations. Use SPRG0
for the current per-CPU control. This reduces the code size by three
instructions and is slightly faster.
Update #2805.
The SMP ticket lock release turned out to be suitable for inlining, e.g.
a hand full of instructions, no branches.
The changes in the screen files do not reflect the changes due to this
commit. However, they are now up to date. Obtained on a T4240 running
at 1.5GHz using GCC 7.0.0 20161108..
Add plot script.
This demonstrates the effect of false cache line sharing in case of
Classic mutexes.
This define accidentally re-appeared.
Add rtems_test_parallel_get_task_id().
