Updates #3053.
- Add a small memory test config file.
- Update the small memory PowerPC BSPs to use the new test config.
maintain.
Update #3254.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
* tm30/init.c: Make benchmark_barrier_create,
benchmark_barrier_ident, benchmark_barrier_delete static.
* Makefile.am, configure.ac: New test for barrier create, ident, and
delete.
* tm30/.cvsignore, tm30/Makefile.am, tm30/init.c, tm30/tm30.doc: New
files.
