path: root/testsuites/tmtests/tm05/system.h (follow)
* Do not define CONFIGURE_TICKS_PER_TIMESLICE to 0Sebastian Huber2024-03-201-1/+0
| | | | | | | Unconditionally make a CONFIGURE_TICKS_PER_TIMESLICE value less than or equal to zero an error. Update #4986.
* testsuites/tmtests/*: Change license to BSD-2Joel Sherrill2022-04-071-3/+22
| | | | Updates #3053.
* Remove coverhd.hSebastian Huber2017-11-241-1/+0
| | | | | | | This header file contained timing overhead values which are hard to maintain. Update #3254.
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* Remove stray white spaces.Ralf Corsepius2004-04-201-2/+2
* * tm01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.Ralf Corsepius2004-04-011-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tm02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm13/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm14/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm15/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm16/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm17/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm18/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm19/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm20/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm21/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm22/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm23/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm24/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm25/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm26/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm27/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm28/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm29/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tmck/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tmoverhd/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* 2004-03-30 David Querbach <querbach@realtime.bc.ca>Joel Sherrill2004-03-301-3/+1
| | | | | | | | | | | | | | | PR 597/tests * tm02/system.h, tm03/system.h, tm04/system.h, tm05/system.h, tm06/system.h, tm07/system.h, tm08/system.h, tm10/system.h, tm11/system.h, tm12/system.h, tm13/system.h, tm14/system.h, tm15/system.h, tm16/system.h, tm17/system.h, tm18/system.h, tm19/system.h, tm21/system.h, tm22/system.h, tm23/system.h, tm24/system.h, tm25/system.h, tm26/system.h, tm27/system.h, tm27/task1.c, tm29/system.h: The actual workspace needed by the tmtests depends on OPERATION_COUNT, but the definitions of CONFIGURE_MAXIMIM_xxx in the their system.h files do not reflect this. This results in unnecessary memory exhaustion on small-memory systems such as the SS555.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/timesys.h, tm01/system.h, tm01/task1.c, tm01/tm01.doc, tm02/system.h, tm02/task1.c, tm02/tm02.doc, tm03/system.h, tm03/task1.c, tm03/tm03.doc, tm04/system.h, tm04/task1.c, tm04/tm04.doc, tm05/system.h, tm05/task1.c, tm05/tm05.doc, tm06/system.h, tm06/task1.c, tm06/tm06.doc, tm07/system.h, tm07/task1.c, tm07/tm07.doc, tm08/system.h, tm08/task1.c, tm08/tm08.doc, tm09/system.h, tm09/task1.c, tm09/tm09.doc, tm10/system.h, tm10/task1.c, tm10/tm10.doc, tm11/system.h, tm11/task1.c, tm11/tm11.doc, tm12/system.h, tm12/task1.c, tm12/tm12.doc, tm13/system.h, tm13/task1.c, tm13/tm13.doc, tm14/system.h, tm14/task1.c, tm14/tm14.doc, tm15/system.h, tm15/task1.c, tm15/tm15.doc, tm16/system.h, tm16/task1.c, tm16/tm16.doc, tm17/system.h, tm17/task1.c, tm17/tm17.doc, tm18/system.h, tm18/task1.c, tm18/tm18.doc, tm19/system.h, tm19/task1.c, tm19/tm19.doc, tm20/system.h, tm20/task1.c, tm20/tm20.doc, tm21/system.h, tm21/task1.c, tm21/tm21.doc, tm22/system.h, tm22/task1.c, tm22/tm22.doc, tm23/system.h, tm23/task1.c, tm23/tm23.doc, tm24/system.h, tm24/task1.c, tm24/tm24.doc, tm25/system.h, tm25/task1.c, tm25/tm25.doc, tm26/fptest.h, tm26/system.h, tm26/task1.c, tm26/tm26.doc, tm27/system.h, tm27/task1.c, tm27/tm27.doc, tm28/system.h, tm28/task1.c, tm28/tm28.doc, tm29/system.h, tm29/task1.c, tm29/tm29.doc, tmck/system.h, tmck/task1.c, tmck/tmck.doc, tmoverhd/dumrtems.h, tmoverhd/empty.c, tmoverhd/system.h, tmoverhd/testtask.c, tmoverhd/tmoverhd.doc: URL for license changed.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-4/+2
* Backed out change that increased the minimum stack size since itJoel Sherrill1999-11-021-1/+0
| | | | | was unnecessary. The real fix was an alignment error in the object extend memory allocation scheme.
* Increased stack space for all initialization tasks in tmtests.Joel Sherrill1999-11-011-0/+1
* tests now specify whether they are using rtems initialization tasksJoel Sherrill1996-05-301-0/+2
| | | | or posix initialization threads
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-1/+22
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-7/+5
* Initial revisionJoel Sherrill1995-05-111-0/+23
