Updates #3053.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
* spwkspace/init.c: Test _Workspace_String_duplicate().
* spwkspace/init.c: Adjust test to account for recent heap change on
NULL.
* sp18/init.c, sp31/task1.c, sp43/init.c, sp63/init.c, sp64/init.c,
spfatal10/testcase.h, spfatal11/testcase.h, spobjgetnext/init.c,
spwkspace/init.c: Use rtems_test_assert() consistently instead of
system assert(). rtems_test_assert() is designed to integrate into
the RTEMS test suite infrastructure.
* Makefile.am, configure.ac, spwatchdog/system.h,
spwkspace/Makefile.am, spwkspace/init.c: Add shell of test for
printk. These will help coverage. Simplify spwkspace.
* spprintk/.cvsignore, spprintk/Makefile.am, spprintk/init.c,
spprintk/spprintk.scn: New files.
* spwkspace/system.h: Removed.
* Makefile.am, configure.ac: New test to exercise rtems_workspace_XXX
methods.
* spwkspace/.cvsignore, spwkspace/Makefile.am, spwkspace/init.c,
spwkspace/spwkspace.scn, spwkspace/system.h: New files.
