path: root/testsuites/sptests/sptask_err02 (follow)
* testsuites/sptests/sp[s-z]*: Change license to BSD-2Joel Sherrill2022-04-052-6/+44
| | | | Updates #3053.
* testsuite/sptests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-22/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* Replace www.rtems.com with www.rtems.orgSebastian Huber2015-03-202-2/+2
* sptests: New tests split from sp09 screen 1 and screen 2.Bjorn Larsson2014-03-285-0/+215
Split sp09 screen 1 into new test sptask_err04. Split sp09 screen 2 into new tests sptask__err02 and spclock_err01, as well as moving one verification into sptimer_err01.
