* | testsuites/sptests/sp[i-z]*/*.doc: Change license to BSD-2 | Joel Sherrill | 2022-04-05 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | 2009-07-02 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-02 | 1 | -0/+24 |
* Makefile.am, configure.ac: Add new test for user configured stack allocator/deallocator. Test both pass and fail cases. * spstkalloc/.cvsignore, spstkalloc/Makefile.am, spstkalloc/init.c, spstkalloc/spstkalloc.doc, spstkalloc/spstkalloc.scn: New files. |
