path: root/testsuites/sptests/spsem01 (follow)
* testsuites/sptests/sp[s-z]*: Change license to BSD-2Joel Sherrill2022-04-051-3/+22
| | | | Updates #3053.
* tests: Use rtems_task_exit()Sebastian Huber2018-10-051-2/+1
| | | | Update #3533.
* testsuite/sptests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-21/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* score: PR788: Add INTERNAL_ERROR_RESOURCE_IN_USESebastian Huber2014-04-032-8/+7
| | | | | | | | | | | | | | | Issue a fatal error in case a thread is deleted which still owns resources (e.g. a binary semaphore with priority inheritance or ceiling protocol). The resource count must be checked quite late since RTEMS task variable destructors, POSIX key destructors, POSIX cleanup handler, the Newlib thread termination extension or other thread termination extensions may release resources. In this context it would be quite difficult to return an error status to the caller. An alternative would be to place threads with a non-zero resource count not on the zombie chain. Thus we have a resource leak instead of a fatal error. The terminator thread can see this error if we return an RTEMS_RESOURCE_IN_USE status for the rtems_task_delete() for example.
* tests/sptests: Use <rtems/test.h>Sebastian Huber2014-03-251-2/+6
* sptests/spsem0[12]: Use rtems_test_exit()Sebastian Huber2014-02-051-2/+2
* sptests: add test for priority inversion with multiple locksGedare Bloom2013-05-204-0/+209
