The previous vprintk() implementation had a questionable licence header,
lacks support for the 'z' and 'j' format specifiers, is not robust
against invalid format specifiers, uses a global variable for output.
Replace it with a stripped down version of the FreeBSD kernel kvprintf()
function.
The new implementation allows a low overhead rtems_snprintf() if
necessary.
Update #3199.
Close #3216.
* spprintk/init.c, spprintk/spprintk.doc, spprintk/spprintk.scn: Clean
up and add test of getchark().
* spprintk/spprintk.scn: Add end of line at end of file.
* Makefile.am, configure.ac, spprintk/init.c, spprintk/spprintk.scn:
Enhance spprintk. Add two new fatal error tests to cover
__assert_func.
* spfatal11/.cvsignore, spfatal11/Makefile.am, spfatal11/init.c,
spfatal11/spfatal11.doc, spfatal11/spfatal11.scn: New files.
* Makefile.am, configure.ac, spwatchdog/system.h,
spwkspace/Makefile.am, spwkspace/init.c: Add shell of test for
printk. These will help coverage. Simplify spwkspace.
* spprintk/.cvsignore, spprintk/Makefile.am, spprintk/init.c,
spprintk/spprintk.scn: New files.
* spwkspace/system.h: Removed.
