brains GmbH.
Updates #3053.
Updates #4625.
Make the initialization of the per-CPU data optional.
Change license to BSD-2-Clause according to file history and
re-licensing agreement.
Update #3053.
Make sure PER_CPU_DATA_OFFSET() is tested also in uniprocessor
configurations.
Update #3732.
Add uniprocessor version for PER_CPU_DATA_GET_BY_OFFSET(). Fix warnings
in uniprocessor configurations.
Update #3507.
Update #3507.
