brains GmbH.
Updates #3053.
There were not a lot of these and they did not match the patterns
of the C.
Updates #4625.
* spnsext01/.cvsignore, spnsext01/Makefile.am, spnsext01/init.c,
spnsext01/spnsext01.doc, spnsext01/spnsext01.scn: New files.
* Makefile.am, configure.ac: Reflect changes above.
