brains GmbH.
Updates #3053.
Updates #4625.
Update #3753.
This configuration is superfluous in these tests.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
PR 1663/testing
* spmkdir/init.c, spmkdir/spmkdir.scn: Added some test outputs to
the test.
PR 1663/testing
* spmkdir/init.c: New cases to get the error path in rtems_mkdir
routine.
* spmkdir/.cvsignore, spmkdir/Makefile.am, spmkdir/init.c,
spmkdir/spmkdir.doc, spmkdir/spmkdir.scn: New files.
