* | tests: Improve RTEMS_DEFINE_GLOBAL_SYMBOL() tests | Sebastian Huber | 2023-09-13 | 1 | -2/+9 |
| | | | | | | | Use a symbol value relative to an existing symbol address to make the test work on more code models. Update #4953. | ||||
* | Update company name | Sebastian Huber | 2023-05-20 | 3 | -3/+3 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | testsuites/sptests/sp[g-r]*: Change license to BSD-2 | Joel Sherrill | 2022-04-05 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | bsps/testsuites/: Scripted embedded brains header file clean up | Joel Sherrill | 2022-03-10 | 1 | -6/+0 |
| | | | | Updates #4625. | ||||
* | spmisc01: Test RTEMS_NOINIT | Sebastian Huber | 2021-05-02 | 1 | -0/+5 |
| | | | | Close #3866. | ||||
* | spmisc01: Include missing header file | Sebastian Huber | 2020-07-24 | 1 | -0/+2 |
| | | | | Update #4032. | ||||
* | score: Add RTEMS_WEAK | Sebastian Huber | 2020-07-24 | 3 | -0/+107 |
* | score: Delete RTEMS_DECLARE_GLOBAL_SYMBOL() | Sebastian Huber | 2020-04-08 | 1 | -7/+0 |
| | | | | | | Delete unused RTEMS_DECLARE_GLOBAL_SYMBOL(). Update #3799. | ||||
* | score: Add RTEMS_DEFINE_GLOBAL_SYMBOL_IN_SECTION() | Sebastian Huber | 2019-10-28 | 1 | -0/+7 |
* | score: Add RTEMS_RETURN_ADDRESS() | Sebastian Huber | 2019-08-28 | 1 | -1/+6 |
* | spmisc01: Use RTEMS_CONST | Sebastian Huber | 2019-04-09 | 2 | -0/+7 |
| | | | | Update #3734. | ||||
* | score: RTEMS_PREDICT_TRUE(), RTEMS_PREDICT_FALSE() | Sebastian Huber | 2018-07-25 | 1 | -0/+25 |
| | | | | | | | Add RTEMS_PREDICT_TRUE() and RTEMS_PREDICT_FALSE() for static branch prediction hints. Close #3475. | ||||
* | spmisc01: Add test cases for basedefs.h stuff | Sebastian Huber | 2018-06-21 | 2 | -0/+225 |
* | score: Macros to declare and define global symbols | Sebastian Huber | 2018-06-21 | 3 | -0/+64 |
Add RTEMS_DEFINE_GLOBAL_SYMBOL() and add RTEMS_DECLARE_GLOBAL_SYMBOL(). Update #3459. |
