brains GmbH.
Updates #3053.
The CONFIGURE_DISABLE_SMP_CONFIGURATION configuration option and
rtems_configuration_is_smp_enabled() were added during the SMP support
development cycle as a workaround to fix some testsuite failures in SMP
configurations. All use cases were replaced with tests for specific
conditions. The configuration option and test macro were undocumented.
Close #3876.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Enable the SMP configuration by default in case SMP is enabled. Add
configuration option CONFIGURE_DISABLE_SMP_CONFIGURATION to disable it
explicitly.
Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which would fail
otherwise.
Update #3001.
This avoids test durations of more than one hour on fast targets, since
fast targets can count a lot during one clock tick period, so the minor
loop iteration count was quite high. Estimate now the test body
duration to iterate only through the interesting time window.
Add and use interrupt_critical_section_test().
* sp59/init.c, spintrcritical15/init.c, spintrcritical16/init.c:
Correct minor issues uncovered on uC5282.
* Makefile.am, configure.ac: Add test case for processing a timeout
on a thread (that is the thread executing) that has also had its
request satisfied while it is being enqueued.
* spintrcritical16/.cvsignore, spintrcritical16/Makefile.am,
spintrcritical16/init.c, spintrcritical16/spintrcritical16.doc,
spintrcritical16/spintrcritical16.scn: New files.
* spintrcritical15/init.c: Remove unused TSR>
* Makefile.am, configure.ac: Add test case for a thread timing out on a
thread queue while another thread is in the process of blocking on
the same thread queue.
* spintrcritical15/.cvsignore, spintrcritical15/Makefile.am,
spintrcritical15/init.c, spintrcritical15/spintrcritical15.doc,
spintrcritical15/spintrcritical15.scn: New files.
