Update #3753.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Return an error status with errno set to ENOSYS during node creation for
nodes not available in the current configuration.
Allow creation of nodes with an unsupported type. Later the usage of
such nodes will return an error status.
* Makefile.am, configure.ac: Removed some fifo tests.
* spfifo01/Makefile.am, spfifo01/init.c: Minor changes to avoid
excessive new lines in the output.
spfifo02/Makefile.am, spfifo02/init.c, spfifo02/spfifo02.doc,
spfifo02/spfifo02.scn, spfifo03/Makefile.am: Merge from spfifo08.
Also added a few more cases, mostly from spfifo04/init.c.
* spfifo03/init.c, spfifo03/spfifo03.doc, spfifo03/spfifo03.scn:
Previously was spfifo06. Configure parameter for pipes is used now.
* spfifo04/.cvsignore, spfifo04/Makefile.am, spfifo04/init.c,
spfifo04/spfifo04.doc, spfifo04/spfifo04.scn, spfifo08/.cvsignore,
spfifo08/Makefile.am, spfifo08/init.c, spfifo08/spfifo08.doc,
spfifo08/spfifo08.scn: Removed.
* spfifo01/init.c, spfifo01/spfifo01.doc, spfifo02/init.c,
spfifo02/spfifo02.doc, spfifo03/init.c, spfifo03/spfifo03.doc,
spfifo04/init.c, spfifo04/spfifo04.doc: Modified copyright.
* spfifo01/init.c, spfifo01/spfifo01.scn: Update for IMFS API changes.
* spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am,
spfifo04/Makefile.am: Merged fifo main and test files into the
standard init file. Fixed copyright information.
* spfifo01/init.c, spfifo02/init.c, spfifo03/init.c, spfifo04/init.c:
New files.
* spfifo01/main.c, spfifo01/test.c, spfifo02/main.c, spfifo02/test.c,
spfifo03/main.c, spfifo03/test.c, spfifo04/main.c, spfifo04/test.c:
Removed.
