* | Remove obsolete rtems_gxx_*() implementation | Sebastian Huber | 2022-01-27 | 3 | -53/+0 |
| | | | | | | | | | | | GCC versions prior to 6.1 used a RTEMS thread model based on rtems_gxx_*() functions. GCC version 6.1 or later uses the self-contained synchronization objects of Newlib <sys/lock.h> for the RTEMS thread model. Remove the obsolete implementation. Close #3143. | ||||
* | sptests: Avoid include path magic | Sebastian Huber | 2019-11-12 | 1 | -1/+9 |
| | | | | Update #3818. | ||||
* | testsuite/sptests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -21/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | score: Remove fatal is internal indicator | Sebastian Huber | 2016-12-09 | 1 | -1/+0 |
| | | | | | | | | | The fatal is internal indicator is redundant since the fatal source and error code uniquely identify a fatal error. Keep the fatal user extension is internal parameter for backward compatibility and set it to false always. Update #2825. | ||||
* | libcsupport: Use POSIX keys for GXX key functions | Christian Mauderer | 2014-03-24 | 2 | -5/+3 |
| | | | | | With this patch C++ applications now eventually need additional POSIX-keys and POSIX-key-value-pairs configured. | ||||
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | sptests/spfatal24: Fix NULL pointer access | Sebastian Huber | 2012-11-15 | 1 | -10/+4 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -9/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+4 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -4/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability. | ||||
* | 2011-08-22 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-08-22 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | * spfatal13/testcase.h: Fixed test name. * spfatal05/testcase.h: Increased wait time for slow hardware. * spfatal_support/init.c: Print test name at end of test. * spfatal01/spfatal01.scn, spfatal02/spfatal02.scn, spfatal03/spfatal03.scn, spfatal04/spfatal04.scn, spfatal05/spfatal05.scn, spfatal06/spfatal06.scn, spfatal07/spfatal07.scn, spfatal08/spfatal08.scn, spfatal09/spfatal09.scn, spfatal10/spfatal10.scn, spfatal11/spfatal11.scn, spfatal12/spfatal12.scn, spfatal13/spfatal13.scn, spfatal14/spfatal14.scn, spfatal15/spfatal15.scn, spfatal16/spfatal16.scn, spfatal17/spfatal17.scn, spfatal18/spfatal18.scn, spfatal19/spfatal19.scn, spfatal20/spfatal20.scn, spfatal21/spfatal21.scn, spfatal22/spfatal22.scn, spfatal23/spfatal23.scn, spfatal24/spfatal24.scn, spfatal25/spfatal25.scn: Reflect changes from above. | ||||
* | Removed. | Sebastian Huber | 2010-08-23 | 1 | -587/+0 |
* | 2010-08-23 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-08-23 | 6 | -0/+673 |
* spfatal24/.cvsignore, spfatal24/Makefile.am, spfatal24/spfatal24.doc, spfatal24/spfatal24.scn, spfatal24/testcase.h, spfatal25/.cvsignore, spfatal25/Makefile.am, spfatal25/spfatal25.doc, spfatal25/spfatal25.scn, spfatal25/testcase.h: New files. * Makefile.am, configure.ac: Reflect changes above. |
