path: root/testsuites/sptests/spfatal09/init.c (follow)
* testsuites/sptests/sp[a-f*]*: Change license to BSD-2Joel Sherrill2022-04-051-3/+22
| | | | Updates #3053.
* bsps: Rework work area initializationSebastian Huber2020-02-041-4/+30
| | | | | | | | | | | | | | | | | | | | The work area initialization was done by the BSP through bsp_work_area_initialize(). This approach predated the system initialization through the system initialization linker set. The workspace and C program heap were unconditionally initialized. The aim is to support RTEMS application configurations which do not need the workspace and C program heap. In these configurations, the workspace and C prgram heap should not get initialized. Change all bsp_work_area_initialize() to implement _Memory_Get() instead. Move the dirty memory, sbrk(), per-CPU data, workspace, and malloc() heap initialization into separate system initialization steps. This makes it also easier to test the individual initialization steps. This change adds a dependency to _Heap_Extend() to all BSPs. This dependency will be removed in a follow up change. Update #3838.
* sptests: Avoid include path magicSebastian Huber2019-11-121-0/+32
Update #3818.
