* | Remove INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL | Sebastian Huber | 2018-09-21 | 1 | -20/+0 |
| | | | | | | | | | | | | The configured interrupt stack size (CONFIGURE_INTERRUPT_STACK_SIZE) is checked against the minimum task stack size. The minium tasks task stack size is also a configuration option (CONFIGURE_MINIMUM_TASK_STACK_SIZE). So, this check does not really help in case of configuration errors. In addition, the interrupt stack is also re-used as the initialization stack in most BSPs. It is probably better to use a stack checker to detect problems. Update #3459. | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | 2009-11-09 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-11-09 | 1 | -0/+23 |
* sp32/Makefile.am, sp33/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spsize/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Add documentation files for multiple tests. * sp32/sp32.doc, sp33/sp33.doc, sp37/sp37.doc, sp38/sp38.doc, sp39/sp39.doc, sp43/sp43.doc, sp44/sp44.doc, spfatal01/spfatal01.doc, spfatal02/spfatal02.doc, spfatal03/spfatal03.doc, spfatal04/spfatal04.doc, spfatal05/spfatal05.doc, spfatal06/spfatal06.doc, spfatal07/spfatal07.doc, spfatal08/spfatal08.doc, spfatal09/spfatal09.doc, spobjgetnext/spobjgetnext.doc, spprintk/spprintk.doc, spsize/spsize.doc, spwatchdog/spwatchdog.doc, spwkspace/spwkspace.doc: New files. |
