path: root/testsuites/sptests/sperror03/sperror03.doc (follow)
* testsuites/sptests/sp[a-h]*/*.doc: Change license to BSD-2Joel Sherrill2022-04-051-3/+22
| | | | Updates #3053.
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-3/+0
* 2010-06-26 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-06-281-0/+22
PR 1592/testing * Makefile.am, configure.ac: Changes to incorporate sperror01, sperror02, sperror03 * sperror01/init.c, sperror02/init.c: New tests to exercise rtems_error routine * sperror03/init.c: New test to exercise rtems_panic routine
