path: root/testsuites/sptests/spedfsched02/getall.c (follow)
* testsuites/sptests/sp[a-f*]*: Change license to BSD-2Joel Sherrill2022-04-051-3/+22
| | | | Updates #3053.
* 2011-09-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-09-291-0/+4
| | | | | | | | | | | * sp75/init.c, spcbssched01/init.c, spcbssched01/task1.c spcbssched02/init.c, spcbssched02/task_periodic.c, spcbssched03/init.c, spcbssched03/tasks_aperiodic.c, spcbssched03/tasks_periodic.c, spedfsched01/init.c, spedfsched01/task1.c, spedfsched02/getall.c, spedfsched02/init.c, spedfsched02/task1.c, spedfsched03/init.c, spedfsched03/tasks_aperiodic.c, spedfsched03/tasks_periodic.c, sprbtree01/init.c: Add HAVE_CONFIG_H.
* 2011-09-11 Petr Benes <benesp16@fel.cvut.cz>Joel Sherrill2011-09-111-0/+47
PR 1897/testing * Makefile.am, configure.ac: Add tests for Earliest Deadline First (EDF) Scheduling Algorithm implementation. * spedfsched01/.cvsignore, spedfsched01/Makefile.am, spedfsched01/init.c, spedfsched01/spedfsched01.doc, spedfsched01/spedfsched01.scn, spedfsched01/system.h, spedfsched01/task1.c, spedfsched02/.cvsignore, spedfsched02/Makefile.am, spedfsched02/getall.c, spedfsched02/init.c, spedfsched02/spedfsched02.doc, spedfsched02/spedfsched02.scn, spedfsched02/system.h, spedfsched02/task1.c, spedfsched03/.cvsignore, spedfsched03/Makefile.am, spedfsched03/edfparams.h, spedfsched03/init.c, spedfsched03/spedfsched03.doc, spedfsched03/spedfsched03.scn, spedfsched03/system.h, spedfsched03/tasks_aperiodic.c, spedfsched03/tasks_periodic.c: New files.
