End the test with a normal exit instead of
INTERNAL_ERROR_THREAD_EXITTED.
Updates #3053.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Replace timestamp implementation with FreeBSD bintime and timecounters.
New test sptests/sptimecounter02.
Update #2271.
Split sp09 screen 1 into new test sptask_err04.
Split sp09 screen 2 into new tests sptask__err02 and spclock_err01,
as well as moving one verification into sptimer_err01.
